auto dimensions double up
oblarry
Go to solution Solved by DRAWZILLA,
i didn't have to delete the existing dimensions before - and if i delete dimensions, i have to delete all dimensions, even interior - is there a setting of some kind, so they don't duplicate?
You know,  I think I agree with you.....  at one time they did not double up and now for some reason they do.......  or am I thinking of auto update exterior dimensions.
Whatever the case,  if you auto dimension,  they should not double up.
With Auto refresh on, you can not reposition the dimension strings after creation. I am not sure I like that very much. Without Auto Refresh on you can reposition but if you hit Auto dim again you will get a second dimension string in the old location but not doubles of the not moved ones.
nice I get it right and Perry gets the Best Answer  :)  :)  :)
what do you mean you can't adjust ?  move out from building? , add extra dim points as needed? cos I can do that no issue with the edit handles , at least on my test plan just now , and it how I remembering it working , I usually have it one as you only get to use the Button ONCE :)
To flush out this point further, if you don't like using auto refresh such as myself, the auto dimension will delete and replace existing auto dimensions if you leave them alone.  Once edited they stay put, which frankly I am glad of.
  • 5 months later...
