builtright3 Posted June 25, 2015 Share Posted June 25, 2015 I cant figure out the materials under this eave. What is it and how do I get rid of it? Link to comment Share on other sites More sharing options...
Kbird1 Posted June 25, 2015 Share Posted June 25, 2015 you know better to ask without posting the plan looks like your soffit but no idea how you got it up there.... Link to comment Share on other sites More sharing options...
builtright3 Posted June 25, 2015 Author Share Posted June 25, 2015 Why would you need a plan? You should give yourself more credit than that! You right about the soffit. Thank You Mick! Link to comment Share on other sites More sharing options...
Kbird1 Posted June 25, 2015 Share Posted June 25, 2015 Ok great... but that's a trick I might need one day ...how did you do it ? M. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 25, 2015 Share Posted June 25, 2015 It's adjusted by the sub fascia size Link to comment Share on other sites More sharing options...
builtright3 Posted June 25, 2015 Author Share Posted June 25, 2015 I just unchecked soffits in the roof plan specification dbx Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 25, 2015 Share Posted June 25, 2015 I was just saying that the location of the soffit is controlled by the sub-fascia Link to comment Share on other sites More sharing options...
builtright3 Posted June 26, 2015 Author Share Posted June 26, 2015 I was just saying that the location of the soffit is controlled by the sub-fascia Yes but I don't understand what you mean by that. I was just trying to figure that out now. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 26, 2015 Share Posted June 26, 2015 Perry was answering my Question Joey on how you got the soffit up that high , not your reply on how you fixed it , looking at you section view I now see you must have subfascia's off or set to say 1/16th" or something , so P. answer makes sense. Thanks P. M Link to comment Share on other sites More sharing options...
builtright3 Posted June 26, 2015 Author Share Posted June 26, 2015 Perry was answering my Question Joey on how you got the soffit up that high , not your reply on how you fixed it , looking at you section view I now see you must have subfascia's off or set to say 1/16th" or something , so P. answer makes sense. Thanks P. M Yes here are my settings and of course I don't mind sharing anything. This system of building patio covers is working well. After I figured it out I did three other different sized patio's for other jobs. One is more like a gazebo that is way in the back yard by the pool, two are attached and the one that you have already seen. Learning how to manipulate all the framing materials to work how I wanted and have it all frame automatic was the hardest to figure out but works well once you get it down. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 26, 2015 Share Posted June 26, 2015 Thanks , yep they look good , wish things were that busy here..... don't forget to check out the Knowledgebase when doing something new , never know what you might find.......... http://www.chiefarchitect.com/support/article/KB-00598/ I think this was the method you used but this KB isn't online anymore , not sure you need it but I had made a PDF of it so Pole Barn Structure.pdf Link to comment Share on other sites More sharing options...
builtright3 Posted June 26, 2015 Author Share Posted June 26, 2015 Thanks , yep they look good , wish things were that busy here..... don't forget to check out the Knowledgebase when doing something new , never know what you might find.......... http://www.chiefarchitect.com/support/article/KB-00598/ I think this was the method you used but this KB isn't online anymore , not sure you need it but I had made a PDF of it so Pole Barn Structure.pdf That's exactly how I did it and I didn't even look at the instructions!!! But how were the knee braces created? Link to comment Share on other sites More sharing options...
Kbird1 Posted June 26, 2015 Share Posted June 26, 2015 I wondered that too , but I think the Article mentioned using the Ones in the Library , though I have seen KB articles where it was obvious they didn't do the KB in the version/title mentioned. As far as I know there are no knee braces like the plain 6x6 at 45° in the Library that you wanted and what is there are called Brackets not Braces , put braces in the search and you will get nothing. you can use the Brackets provided with a little cheating too Personally I prefer the look of what CA calls the Ranch Bracket (no#2) , little more decorative. Link to comment Share on other sites More sharing options...
builtright3 Posted June 26, 2015 Author Share Posted June 26, 2015 When I get off the lake I will have to figure it out. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 26, 2015 Share Posted June 26, 2015 Nice..... 32 deg. here today so that would be the go.... Link to comment Share on other sites More sharing options...
builtright3 Posted June 26, 2015 Author Share Posted June 26, 2015 Nice..... 32 deg. here today so that would be the go.... 78 degrees here in Big Bear and so far they have spent 17 million trying to put out the fire. Link to comment Share on other sites More sharing options...
Rich_Winsor Posted June 27, 2015 Share Posted June 27, 2015 When I get off the lake I will have to figure it out. What keeps the water from falling out of the lake? Link to comment Share on other sites More sharing options...
Kbird1 Posted June 27, 2015 Share Posted June 27, 2015 78 degrees here in Big Bear and so far they have spent 17 million trying to put out the fire. for you 32° is 90° tried to look at pic , but I'm a couple of injuries past swivelling my head that far around. Link to comment Share on other sites More sharing options...
builtright3 Posted June 27, 2015 Author Share Posted June 27, 2015 for you 32° is 90° tried to look at pic , but I'm a couple of injuries past swivelling my head that far around. The picture just states how I feel. I don't why it went in upside down Link to comment Share on other sites More sharing options...
Kbird1 Posted June 27, 2015 Share Posted June 27, 2015 I have seen on other Forums that iPhone picks come in upside down but don't own one myself so not sure of the reason Link to comment Share on other sites More sharing options...
builtright3 Posted June 28, 2015 Author Share Posted June 28, 2015 I have seen on other Forums that iPhone picks come in upside down but don't own one myself so not sure of the reason I don't have an I phone either. I'm a die hard widows based computer and droid user. No fruit (apple products) in my life except for the fruit of the spirit! Link to comment Share on other sites More sharing options...
Kbird1 Posted June 28, 2015 Share Posted June 28, 2015 maybe just the orientation when you took the piic ...(phone upside down) most windows programs auto orientate pics so you don't notice this... No fruit here either , I am Windows Comp. + Surface3 and windows phone too , but am close to getting a Android phone , maybe Note4 for app support , though I don't really want to learn another "Ecosystem" Link to comment Share on other sites More sharing options...
builtright3 Posted June 29, 2015 Author Share Posted June 29, 2015 maybe just the orientation when you took the piic ...(phone upside down) most windows programs auto orientate pics so you don't notice this... No fruit here either , I am Windows Comp. + Surface3 and windows phone too , but am close to getting a Android phone , maybe Note4 for app support , though I don't really want to learn another "Ecosystem" I have the note 4 and I love it! Best phone ever! The camera doesn't get any better with the 16mp. Best phone camera on the market. Also; You know when you take a picture and how it picks up the light from a window and it darkens everything around it? This camera has a quick setting right on the screen that eliminates that problem. I have always had trouble with tying to take kitchen pictures with a window in it because everything around the window goes dark. Not with this camera though! You should check it out. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 29, 2015 Share Posted June 29, 2015 Thanks for the info Joey appreciate it , been sitting on the fence and my Phone.Co has finally got a "deal" for existing users....never mind I have been with them for 22 yrs , new users can usually get a better phone price though .....go figure... Link to comment Share on other sites More sharing options...
dshall Posted June 29, 2015 Share Posted June 29, 2015 When I get off the lake I will have to figure it out. Yep, I will be looking forward to the Big Bear UGM next year at Joey's place. Link to comment Share on other sites More sharing options...
