pfschuyler Posted June 4, 2015 Share Posted June 4, 2015 I'm getting my Chief Architect "legs" and there are two common elements I want to add to a typical full-height closet cabinet. 1.)Angled shelves for shoes. 2.)Hanger rods or pull-down rods. I realize I could add these elements as independent symbols and manually place them...but that's time consuming. Is there a way to add common items like these within the cabinet dialog box (for example a custom profile as a shelf option...which could solve both conditions)? Paul Schuyler Link to comment Share on other sites More sharing options...
tommy1 Posted June 5, 2015 Share Posted June 5, 2015 For both, I would an open cabinet with no shelves. Make an angled shelf, might be easiest to do in an elevation using a polyline solid. Control/drag the shelf inside the cabinet. In a back-clip elevation looking at the front, place it at the top or bottom. Select the shelf, and copy it up or down. Could use transform/replicate to copy it too. For the rod for the shoes, use a solid. Control/drag into the cabinet. Copy it as mentioned. This can be done in about 10 minutes. Link to comment Share on other sites More sharing options...
jcaffee Posted June 5, 2015 Share Posted June 5, 2015 Use the Canyon Creek manufacturer lib. Inside are the Closets Plus symbols. jon Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted June 5, 2015 Share Posted June 5, 2015 If you can find a suitable model, as suggested by Jon, will most likely be your easiest route. Getting an object such as a shelf in Chief to be on an angle is a bit tricky to do. For this you could save a shelf as a symbol and then use the symbol DBX and adjust the angle with the x,y,z rotate options. In camera views you need to aim at the right face of the symbol to get the desired axis rotation handle. Once you have the shelf properly sloped you can then just float it into an open cabinet that the auto shelving has be set to Manual Zero shelves. Graham Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted June 5, 2015 Share Posted June 5, 2015 jon - Nice! Didn't know about that. Link to comment Share on other sites More sharing options...
jcaffee Posted June 5, 2015 Share Posted June 5, 2015 On 6/5/2015 at 12:38 PM, Dennis_Gavin said: jon - Nice! Didn't know about that. Now, getting shoes to sit on those shelves is awholenotherstoryaltogetherdifferent. jon Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted June 5, 2015 Share Posted June 5, 2015 OMG! Did you put that together? Link to comment Share on other sites More sharing options...
jcaffee Posted June 5, 2015 Share Posted June 5, 2015 Yes, and it was a PITA of mass proportions! jon Link to comment Share on other sites More sharing options...
jcaffee Posted June 5, 2015 Share Posted June 5, 2015 Detailing closets and wine cellars... "Hello, suicide hotline?" jon Link to comment Share on other sites More sharing options...
Kbird1 Posted June 5, 2015 Share Posted June 5, 2015 There is an angled Shelf and other items like Rods in the Closet Accessories Library>Hardware and other Items like Cubbies (cubes) in the Cabinet Specialty Storage Library too. @ Jon ...very nice... Link to comment Share on other sites More sharing options...
CJSpud Posted June 5, 2015 Share Posted June 5, 2015 Jon: Very nice!! Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted June 5, 2015 Share Posted June 5, 2015 Nice job Jon. By any chance, if I were to zoom in does each bottle have a different label. I'm thinking a nice Bordeaux !! for tonight's dinner would work well. Graham Link to comment Share on other sites More sharing options...
jcaffee Posted June 5, 2015 Share Posted June 5, 2015 Mick, I could never get the angled shelf to insert automatically using any of the cabinet "Front" settings or the library insert. Guess I'm too lazy as I realize (as I'm typing this) that all I need to do is make a copy and adjust the Y offset. D'oh! jon Link to comment Share on other sites More sharing options...
jcaffee Posted June 5, 2015 Share Posted June 5, 2015 G, let me check... ... ... oopps, it appears the staff found the cellar key, again. jon Link to comment Share on other sites More sharing options...
Kbird1 Posted June 6, 2015 Share Posted June 6, 2015 Must be the Client class I deal with Jon I just throw them in the bottom of the Closet.... but you can resize and drag into a cabinet . Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted June 6, 2015 Share Posted June 6, 2015 jon - hopefully you are good friends with the array and multiple copy tools! very nice! Link to comment Share on other sites More sharing options...
jcaffee Posted June 6, 2015 Share Posted June 6, 2015 Dennis, yes, yes I am. Learning to populate shelves of all sorts is a chore, but those replicate features make it almost--naw, it's still a chore. jon Link to comment Share on other sites More sharing options...
