mtldesigns Posted 1 hour ago Share Posted 1 hour ago @Renerabbitt And whomever else are good at these kind of views. There's a few of you out there, names are not coming to mind. I usually don't spend a lot of time on PBRs, basically OOTB settings. They usually turn out good enough for presentation sakes. HOWEVER this one house I am doing, I just cant get the PBR to show the mountains through the glass. This is why the lot was sold to my client and why they want a house that they can see those mountains from inside. The least I can do is give them a representation of that view, right? I have spent a good hour on these few views, and I played with every setting that I know of, every sun position, sun intensity and even turned the glass to air insulation.... it just isn't coming through. I even tried Chat GPT.. looks cheesy IMO. Is there a setting or two that I need to adjust.. Thank you in advance. Link to comment Share on other sites More sharing options...
scottharris Posted 42 minutes ago Share Posted 42 minutes ago Michael, try setting your backdrop intensity to ~500. Here's a good resource BTW - https://www.chiefarchitect.com/videos/watch/1977/interior-ray-tracing.html?playlist=103 Link to comment Share on other sites More sharing options...
