winterdd Posted August 20, 2025 Share Posted August 20, 2025 Howdy folks, I am sure some of you have experienced this like I have over the years and I am finally going to ask why it happens. Why does the text in both plan and layout files shift sometimes? I have narrowed it down to two things in common and that is when I have to hold down "control" and zoom in on my pc to make the screen bigger or smaller (different scenarios require that sometimes) or I upgrade to a new computer. I can then open up a set of plans I have already worked on and have to go through and adjust each text and stretch the grip to make it go back to normal and that is very time consuming. Any tips on this (if any of this makes sense to you all)? Example below......... before after Link to comment Share on other sites More sharing options...
Rookie65 Posted August 20, 2025 Share Posted August 20, 2025 Looks to me like it's an issue with the size of the text box you want to fit it in. On your image on the left, look at the space between the 2407 and the right edge. Then on the right image, it's a larger distance and it fits. Sometime just need to drag the text box a little to make it go away. 1 Link to comment Share on other sites More sharing options...
Smn842 Posted August 20, 2025 Share Posted August 20, 2025 As a software developer I know sizing of text to an area is a difficult area across different devices, OS, font scaling etc. I don't know the internals of Chief so it could be a different issue, but I've had to resolve problems like this in various applications when text only just fits an bounding area as this can lead to unexpected issues such as you'be seen in Chief. I commented a bit more about this type of issue a while back: Link to comment Share on other sites More sharing options...
winterdd Posted August 20, 2025 Author Share Posted August 20, 2025 Ok, so I am not crazy then. Looks like lots of feedback on your thread. Link to comment Share on other sites More sharing options...
winterdd Posted August 20, 2025 Author Share Posted August 20, 2025 1 hour ago, Rookie65 said: On your image on the left, look at the space between the 2407 and the right edge. Then on the right image, it's a larger distance and it fits. You are right, I had to stretch the box to get it to fit right> Keep in mind, these plans were already completed and delivered months ago. When I opened it today the text was all jacked up. Link to comment Share on other sites More sharing options...
robdyck Posted August 20, 2025 Share Posted August 20, 2025 5 hours ago, winterdd said: Any tips on this (if any of this makes sense to you all) Tips: Avoid Rich Text wherever possible. This is significantly less important in X16 and X17. If you are sticking with X15 or older versions, and you have re-usable text from CAD blocks, details, library items, etc., it could be worth replacing Rich Text with standard Text wherever you can. Upgrade to X17. 1 1 Link to comment Share on other sites More sharing options...
winterdd Posted August 21, 2025 Author Share Posted August 21, 2025 15 hours ago, robdyck said: Tips: Avoid Rich Text wherever possible. This is significantly less important in X16 and X17. If you are sticking with X15 or older versions, and you have re-usable text from CAD blocks, details, library items, etc., it could be worth replacing Rich Text with standard Text wherever you can. Upgrade to X17. What is the main difference with rich text though? Link to comment Share on other sites More sharing options...
robdyck Posted August 21, 2025 Share Posted August 21, 2025 1 hour ago, winterdd said: What is the main difference with rich text though? Aside from different editing capabilities and other properties, the main difference is that it is...different than standard text. Specifically when it comes to the text box size issue, this is a Rich Text problem, not a standard text problem. Link to comment Share on other sites More sharing options...
Chrisb222 Posted August 21, 2025 Share Posted August 21, 2025 1 hour ago, winterdd said: What is the main difference with rich text though? A Rich Text object can contain text made up of multiple fonts, multiple type styles, multiple sizes, and colors. Plain Text cannot. However, the Plain text font, size, color, and style can all be controlled by its Layer, making it very versatile for showing different text effects on different plan views. Two very different tools. Link to comment Share on other sites More sharing options...
winterdd Posted August 21, 2025 Author Share Posted August 21, 2025 Yeah, from the very first time I used CA and pulled a leader line with text it was rich text so that's what I used from day one. Link to comment Share on other sites More sharing options...
DBCooper Posted August 21, 2025 Share Posted August 21, 2025 Also, if you want to use the leader line tool but create plain text instead of rich text, there is a preference setting to control that. Link to comment Share on other sites More sharing options...
OasisStudio Posted September 26, 2025 Share Posted September 26, 2025 (edited) On 8/21/2025 at 11:31 AM, DBCooper said: Also, if you want to use the leader line tool but create plain text instead of rich text, there is a preference setting to control that. I was going to ask where, I decided to look one more time. In case anyone's as blind as me.... Edited September 26, 2025 by OasisStudio Link to comment Share on other sites More sharing options...
