Carpenter4 Posted April 4, 2015 Author Share Posted April 4, 2015 All, thanks for your help but I still don't seem to have a solution. builtright3 suggested using the "materials area select tool" which works fine for a square room but what if the room is not square. I would think I should be able to just click in a room and get the materials list including wall board. Attached is a basement project and I feel I should be able to get the material list for the two finished rooms. Link to comment Share on other sites More sharing options...
Kbird1 Posted April 4, 2015 Share Posted April 4, 2015 All, thanks for your help but I still don't seem to have a solution. builtright3 suggested using the "materials area select tool" which works fine for a square room but what if the room is not square. I would think I should be able to just click in a room and get the materials list including wall board. Attached is a basement project and I feel I should be able to get the material list for the two finished rooms. You should be able to use the Materials List Polyline for that , once you have it shaped as needed, select it, then click the Calculate Button on the edit Toolbar, it works like the "calculate from area Tool" so whatever is inside your shaped "marquee" is included. Link to comment Share on other sites More sharing options...
glennw Posted April 5, 2015 Share Posted April 5, 2015 Glenn, where specifically is this Areas-Sheet setting you are referring to ? MickeyToo, To create a new material in the library: Open the Library Browser. Right click on User Catalog...New...Material. General panel...Specifications...Material Type. Choose your poison. You can also get there through the Plan Materials dbx and then Edit existing materials, create new materials, etc. Link to comment Share on other sites More sharing options...
builtright3 Posted April 6, 2015 Share Posted April 6, 2015 Rethinking my previous posts. I am a remodeler. When I want to remodel a ROOM it should include what is on the walls. i.e. - repair/replace drywall in master bedroom. I don't look at a room as what is on the floor but the whole room including walls and ceiling. All, thanks for your help but I still don't seem to have a solution. builtright3 suggested using the "materials area select tool" which works fine for a square room but what if the room is not square. I would think I should be able to just click in a room and get the materials list including wall board. Attached is a basement project and I feel I should be able to get the material list for the two finished rooms. I agree also that you should be able to see all the materials for an individual room when you select "room materials" tool. Is there any way that this could be corrected with CA? Link to comment Share on other sites More sharing options...
lbuttery Posted April 6, 2015 Share Posted April 6, 2015 Is there any way that this could be corrected with CA? Yes, post a suggestion in the suggestions section of the forum CA will then add it to their database of requests when it will be "fixed" depends on priorities Lew Link to comment Share on other sites More sharing options...
builtright3 Posted April 6, 2015 Share Posted April 6, 2015 Is there any way that this could be corrected with CA? Yes, post a suggestion in the suggestions section of the forum CA will then add it to their database of requests when it will be "fixed" depends on priorities Lew Squeaky wheel gets the oil. The more that suggest it the sooner it may get done. I will do that right now. Link to comment Share on other sites More sharing options...
Doug_Park Posted April 6, 2015 Share Posted April 6, 2015 You can also create a room polyline, then convert it to a material polyline. Using Concentric resize you should be able to quickly get it to include the sheet rock. Link to comment Share on other sites More sharing options...
