winterdd Posted Sunday at 11:04 PM Share Posted Sunday at 11:04 PM Hey guys, anyone know why metal siding renders like this. The upper portion often has a different contrast. Not a big deal but it would be nice to showcase my work to the client even for the smallest jobs like this. Link to comment Share on other sites More sharing options...
GeneDavis Posted Sunday at 11:20 PM Share Posted Sunday at 11:20 PM I see the diff in the gable and also above below and adjacent the front windows. Have you tried simply eyedropping from good and painting on bad? Link to comment Share on other sites More sharing options...
winterdd Posted Sunday at 11:37 PM Author Share Posted Sunday at 11:37 PM 12 minutes ago, GeneDavis said: I see the diff in the gable and also above below and adjacent the front windows. Have you tried simply eyedropping from good and painting on bad? I'm thinking it is lighting because it is fine in standard & vector. I've been overlooking this for years but finally just decided to post this. Again, not a big deal but CA has so many cool features to produce professional and fancy looking plans as my builders have said that this shouldn't be an issue in PBR's. Link to comment Share on other sites More sharing options...
basketballman Posted Sunday at 11:46 PM Share Posted Sunday at 11:46 PM Or run it through A.I. for quick enhancement. Not 100% perfect but getting closer .. Link to comment Share on other sites More sharing options...
para-CAD Posted yesterday at 12:07 AM Share Posted yesterday at 12:07 AM I just tried ChatGPT to render some framing.............it missed on the bottom cords of the trusses https://chatgpt.com/s/m_68744475b4a08191b51c5b7b593c092f 1 Link to comment Share on other sites More sharing options...
mtldesigns Posted yesterday at 12:32 AM Share Posted yesterday at 12:32 AM 1 hour ago, winterdd said: The upper portion often has a different contrast. I've seen this before on my stuff, its random though. I don't remember if I fixed it or not. I want to say, I changed it from an attic wall, but that wouldn't make sense with what you have at the window. @basketballman If only it didn't offset those post, this would be just about perfect. Its getting there.. Did you just upload Rob's picture? Link to comment Share on other sites More sharing options...
winterdd Posted yesterday at 02:03 AM Author Share Posted yesterday at 02:03 AM 2 hours ago, basketballman said: Or run it through A.I. for quick enhancement. Not 100% perfect but getting closer .. That looks great. How did you do that? Link to comment Share on other sites More sharing options...
basketballman Posted 20 hours ago Share Posted 20 hours ago 10 hours ago, mtldesigns said: I've seen this before on my stuff, its random though. I don't remember if I fixed it or not. I want to say, I changed it from an attic wall, but that wouldn't make sense with what you have at the window. @basketballman If only it didn't offset those post, this would be just about perfect. Its getting there.. Did you just upload Rob's picture? Proper prompt would have prevented post offset Link to comment Share on other sites More sharing options...
Renerabbitt Posted 14 hours ago Share Posted 14 hours ago 17 hours ago, winterdd said: Hey guys, anyone know why metal siding renders like this. The upper portion often has a different contrast. Not a big deal but it would be nice to showcase my work to the client even for the smallest jobs like this. That texture likely uses a normal map, and normal map creates directional based height, and chief architect often times flips map orientations, to the upper texture on your attic wall is probably upside down. Baloon frame the ower wall and it would fix it Link to comment Share on other sites More sharing options...
winterdd Posted 10 hours ago Author Share Posted 10 hours ago 4 hours ago, Renerabbitt said: That texture likely uses a normal map, and normal map creates directional based height, and chief architect often times flips map orientations, to the upper texture on your attic wall is probably upside down. Baloon frame the ower wall and it would fix it Thanks, Rene sounds like a good solution. I am also intrigued by other posts on this thread about AI and architecture. Kind of like the internet in the mid to late 90s. Before I had I didn't understand just what it was. Link to comment Share on other sites More sharing options...
