No Terrain under room on piers
Gary-Doski
Try this:
Select the terrain perimeter.
Use the "make terrain hole around building" tool.  This takes the auto generated hole and converts it into a manual terrain hole.
Select the hole and reshape as needed.
  • Upvote 2
  • 1 month later...
On 6/29/2025 at 1:31 PM, CharlesVolz said:
Or, place the terrain on Floor 0 so that cantilevered building areas like boxed windows do not cut a hole in the terrain. Only your foundation walls influence the terrain cut out.
This is how I ended up solving this problem, works great. Keep in mind all your terrain features will have to be on that level as well.
  • 1 month later...
On 9/5/2025 at 9:19 AM, Gary-Doski said:
Yeah, that's how I get it done, then copy it as a cad line to the 1st floor, but seems like it should figure this out automatically
I use floor 0 as well for this exact reason, If I am lazy I will copy the CAD line to floor 1 for certain terrain features, but I also have a saved plan view that references terrain items (from floor 0) to show on floor 1
Edited by SHCanada2
If you use the "make terrain hole" feature, it is then manual and you will have to update it anytime you move walls.  Do whatever you think is easier.  There are times though, like when you have a stepped foundation/floor plan, that moving the terrain down or even up a floor still won't give you what you need.  In these cases, you have to make your own terrain hole.
