No Terrain under room on piers
Gary-Doski
Try this:
Select the terrain perimeter.
Use the "make terrain hole around building" tool.  This takes the auto generated hole and converts it into a manual terrain hole.
Select the hole and reshape as needed.
  • 1 month later...
On 6/29/2025 at 1:31 PM, CharlesVolz said:
Or, place the terrain on Floor 0 so that cantilevered building areas like boxed windows do not cut a hole in the terrain. Only your foundation walls influence the terrain cut out.
This is how I ended up solving this problem, works great. Keep in mind all your terrain features will have to be on that level as well.
  • 1 month later...
On 9/5/2025 at 9:19 AM, Gary-Doski said:
Yeah, that's how I get it done, then copy it as a cad line to the 1st floor, but seems like it should figure this out automatically
I use floor 0 as well for this exact reason, If I am lazy I will copy the CAD line to floor 1 for certain terrain features, but I also have a saved plan view that references terrain items (from floor 0) to show on floor 1
Edited by SHCanada2
