WINDOW LABEL
danilo
did any encounter a label discrepancy in windows?
a window 6040 . My framers always read this has 6ft x 48" like when you actually go to order on a store. but chief architect  interpreted has 5ft by 48" witch is wrong. does any one experience this issue ?
I had some confusion with clients when I first started. What I do now is specify the label as %width%x%height%", and it will put the (") symbol in the description. Or you can put RO before it if you want it to read that way so it comes out as RO 60" x 48". I also put the style window in the description..DH, CSMT, FXD, GLDG, etc. Chief just does them as a default in inches. It doesn't make it wrong. Just need to know how the program does things.
Danilo, is this the same danilo that uses my templates? I just checked my systems across all versions, no such issue. Even the mulled unit shows correctly
Just my thoughts because I have to keep it simple and everyone on the same page to save confusion.
I direct everyone to read off the WINDOW SCHEDULE. You can add all the columns there for what you need.
Framer should follow RO column 60”x42”
Window company should follow SIZE column 5036
Homeowner should follow INCHES column 60”x42”
  • Like 2
I tried that once, then the development authority told me to put them on the plans to get them approved
