gelbuilding Posted yesterday at 03:54 AM Share Posted yesterday at 03:54 AM For stairs, the tread overhang can be adjusted using the style option. However, for the winders at the bottom, which I created using landings, no style option is available. All three winders are constructed from landings, and notably, the first winder connected to the main stairs has no overhang. Is there a workaround solution for removing the overhang on the landing? Link to comment Share on other sites More sharing options...
DBCooper Posted yesterday at 04:21 AM Share Posted yesterday at 04:21 AM It works for me. As long as the landing is connected to the stair, it should pick up the settings from the stair. Not sure why it doesn't work for you so you might want to post your plan. Link to comment Share on other sites More sharing options...
para-CAD Posted yesterday at 05:19 AM Share Posted yesterday at 05:19 AM Winders are pretty hard to make code compliant. 6" at the short point and tread length at the 12" walk line. I sometimes wonder if the code guys fully understand what they are specifying. 2 Link to comment Share on other sites More sharing options...
Mark3D Posted 23 hours ago Share Posted 23 hours ago Upload your file if you can't get it to work Link to comment Share on other sites More sharing options...
