PitMan71 Posted March 18, 2025 Share Posted March 18, 2025 Is there a trick to using the fillet tool to fillet arcs to lines or other arcs? Or is it just not a thing? I was drawing a driveway and I had a parking area off of a drive with an arc and I can't figure out how to fillet the intersecting segments. Thanks Link to comment Share on other sites More sharing options...
basketballman Posted March 18, 2025 Share Posted March 18, 2025 Simple search revealed this .. Link to comment Share on other sites More sharing options...
PitMan71 Posted March 18, 2025 Author Share Posted March 18, 2025 Okay. I googled and got what you posted.... So, I must be doing something wrong then. Seems I need to tinker with that tool a bit more. Thanks for confirming. Link to comment Share on other sites More sharing options...
DBCooper Posted March 18, 2025 Share Posted March 18, 2025 I'm not so sure I would trust google on this one. It's very simple to add a fillet between two straight line segments but I still haven't figured out a way to add a fillet in between a line and an arc or between two arcs. If @basketballmanknows a way, I would love to see how he does it. Link to comment Share on other sites More sharing options...
Chrisb222 Posted March 18, 2025 Share Posted March 18, 2025 I don't think Google is wrong here. The way I read that, it says yes you can fillet arcs... the newly created arc being the result of the fillet action. Key phrase: "add curves to corners" which is exactly what the tool does. I see nothing in the clip saying that it fillets a straight segment into an existing arc. 1 Link to comment Share on other sites More sharing options...
Solution TeaTime Posted March 18, 2025 Solution Share Posted March 18, 2025 1 hour ago, basketballman said: Simple search revealed this .. Huh, so, we're just out here trusting AI Overviews now? @PitMan71 no you really can't. I mean you can use the Fillet tool all you like, but it won't fillet between a line and an arc. When you try to use either Fillet or Chamfer tool between a line and an arc, it "fails" and defaults back to just do an intersect/join on them. Nice that it does SOMETHING but a fillet that is not. You'll see this if when you try to fillet/chamfer between polyline segments that aren't connected: vs I think the program tries to avoid removing polyline edges in these cases, which it would have to do here in order to properly fillet across these two lines, so it just joins them instead. Like, sure why not. Of course, if the line and arc are already connected, then when the Fillet/Chamfer "fails" the result is effectively nothing, since they're already Joined. If you want a nice arc there, just draw a new connecting arc between them then with the new Arc segment selected use the Make Arc Tangent function The default radius it offers is usually pretty decent but you can always enter your own, too 1 1 Link to comment Share on other sites More sharing options...
zoome360 Posted February 7 Share Posted February 7 Is this on a wish list? Seems like something any modern cad program shold be able to do. Link to comment Share on other sites More sharing options...
DBCooper Posted February 7 Share Posted February 7 Quote Is this on a wish list? Seems like something any modern cad program shold be able to do Not unless someone sent it into to Chief. If it is something you want, you should send in a suggestion: https://chieftalk.chiefarchitect.com/forum/8-suggestions/ Link to comment Share on other sites More sharing options...
zoome360 Posted February 7 Share Posted February 7 Thanks, I've added this as a topic in Suggestions. Link to comment Share on other sites More sharing options...
ComputerMaster86 Posted February 9 Share Posted February 9 I have been desiring to fillet arcs in chief for a few years now. The work arounds are a bit of a pain to achieve what I am always after. And then don't even get me started on the fact we can't trim / extend / break ovals and ellipses. I could even go on... More Circle Creation Tools * 3-Point Circle * Circle Tangent to Line * Circle Tangent to Arc / Circle * Circle Tangent to 3 Arcs / Circles Now I am just being silly. Link to comment Share on other sites More sharing options...
