TheoryDesign Posted February 18 Share Posted February 18 Video 704 talks about this but I don't see the same DBX option in Chief Arch v16 to indicate my roofs as "edited". How can I lock my existing roofs? When I check the boxes to "retain manually drawn/edited roofs" under the Build Roof toolbar, it does not do so without that prior step. Link to comment Share on other sites More sharing options...
Fotis1960 Posted February 18 Share Posted February 18 I have it on CA16 Link to comment Share on other sites More sharing options...
TheoryDesign Posted February 18 Author Share Posted February 18 Thanks for confirming that part, Fotis1960. It must be something else then...perhaps a setting when the original roofs were drawn? I'm stuck. Link to comment Share on other sites More sharing options...
ChiefTylerL Posted February 18 Share Posted February 18 Hello, On the Build Roof Dialog you have the option for either Retain Manually Drawn Roof Planes or Retain Edited Automatic Roof Planes. The first option (Retain Manually Drawn Roof Planes) will affect any roof planes that were drawn manually by using the Roof Plane tool. This tool can be found by going to Build> Roof> Roof Plane. You can tell if a roof plane was manually drawn because it will show “Manual Roof Plane”, like it shows in your screenshot. The second option (Retain Edited Automatic Roof Planes) will affect any roof planes that were generated by the Auto Rebuild Roofs or the Build Roof Planes option, and then were manually adjusted or marked as edited. A roof plane will automatically have the “Mark as Edited” checkbox enabled if you made changes to the roof plane after it was generated. (ie. Changing its’ pitch, reshaping, repositioning, etc.). You can certainly have a mix of these roof planes in your file. You can have the ones that were automatically generated by the Build Roof tool, but you could also have some that you manually drew in using the Roof Planes tool. Based off of your screenshot I'm thinking you might have group selected your roof planes. I would instead go one by one and take note of "Mark as Edited" or "Manual Roof Plane". I hope this helps! Link to comment Share on other sites More sharing options...
TheoryDesign Posted February 18 Author Share Posted February 18 Thanks ChiefTylerL - I have tried to select my roofs individually as well & that checkbox still does not show up. I did not create the roofs in the original file, but assume there's nothing unique about them - they had to be created either manually or automatically. If a roof is automatically built but not ever edited does it mean that roof option will not be available? Not sure how to any new roofs w/o affecting the others unless I fully detach my garage from the house to do so. Link to comment Share on other sites More sharing options...
SHCanada2 Posted February 19 Share Posted February 19 You might want to post the plan Link to comment Share on other sites More sharing options...
TheoryDesign Posted February 19 Author Share Posted February 19 Adding more visuals in this order: -existing home w/ existing roofs -proposed garage/mudroom addition before attempting roofs (so just walls) -DBX screen when attempting to build new roofs over addition -roof spaghetti that ensues -floorplan if helpful per SHCanada2 I know the existing house has manually drawn roofs. If I select all or just one of them the DBX still does not provide the option to "mark as edited". I just don't know where that is hiding? If I proceed to "Building Roof" tool & check off "Retain Manually Drawn Roof Planes" box in the DBX, I get new roofs built overtop the existing roofs & it tried to combine these with new roofs over the addition. Technically the existing roofs aren't getting changed, but overbuilt, but still...why would they get involved at all? I clearly still have a lot to learn about roofs, but why wouldn't that "mark as edited" option appear anywhere in my DBX's? Link to comment Share on other sites More sharing options...
SHCanada2 Posted February 19 Share Posted February 19 My apologies, I meant post the Chief .plan file Link to comment Share on other sites More sharing options...
Chrisb222 Posted February 19 Share Posted February 19 3 hours ago, TheoryDesign said: I know the existing house has manually drawn roofs. Did you draw/edit the roof that's on the existing house? Once I get to manual roof planes or edited automatic planes (i.e. no longer auto roofs), I don't try to have anything new auto-built. In other words, why wouldn't you just create new manual roof planes for the garage? That would've been a lot faster than the time you've spent trying to get the program to build them. Link to comment Share on other sites More sharing options...
SHCanada2 Posted February 19 Share Posted February 19 looking a little closer at the screenshots, it looks like CA is making roofs in addition to the manually drawn roofs? This, I think, is expected behaviour as I have this happen all the time and then I delete the auto generated roofs (and turn off the auto build roofs). it is a bit of a PIA if you add some more building and want that portion of the building to auto build. As you have to go build the roofs, and delete the other roofs auto done on the rest of the building. rinse repeat everytime you change the building addition 1 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 20 Share Posted February 20 18 hours ago, SHCanada2 said: looking a little closer at the screenshots, it looks like CA is making roofs in addition to the manually drawn roofs? This, I think, is expected behaviour as I have this happen all the time and then I delete the auto generated roofs (and turn off the auto build roofs). it is a bit of a PIA if you add some more building and want that portion of the building to auto build. As you have to go build the roofs, and delete the other roofs auto done on the rest of the building. rinse repeat everytime you change the building addition I also see the new roof overbuild the existing roofs and have to delete the new roofs; I think it's been that way forever. Link to comment Share on other sites More sharing options...
TheoryDesign Posted February 24 Author Share Posted February 24 On 2/19/2025 at 5:25 PM, Chrisb222 said: Did you draw/edit the roof that's on the existing house? Once I get to manual roof planes or edited automatic planes (i.e. no longer auto roofs), I don't try to have anything new auto-built. In other words, why wouldn't you just create new manual roof planes for the garage? That would've been a lot faster than the time you've spent trying to get the program to build them. The original roofs were drawn by a 3rd party (I use Canvas lidar scanning tool for site measurements to provide my as-built conditions model - fyi major timesaver for those who dread extensive site measuring & it only requires a cell phone to use). I see the existing roofs say "manually drawn" in the dbx. If I try to edit them manually myself it still doesn't provide the option to retain these manually drawn/edited roofs afterward in the dbx. Good point about simply drawing my own roofs manually. Since I don't do much exterior/roof work much I've been worried I might build complex roofs incorrectly & it is largely why I invested in Chief Arch. However, may need to study roof construction a bit to avoid this in the future. Perhaps it's not as complicated as I've been assuming. Link to comment Share on other sites More sharing options...
TheoryDesign Posted February 24 Author Share Posted February 24 On 2/19/2025 at 10:27 AM, SHCanada2 said: You might want to post the plan Thanks SHCanada2 - I actually didn't realize I could do that here (best via zipped file or link to it?). Last week I fudged what I needed but am returning to this now. I'd submitted a ticket to tech support & will post results here afterward in case others need this help too. Link to comment Share on other sites More sharing options...
TheoryDesign Posted February 24 Author Share Posted February 24 On 2/20/2025 at 1:09 PM, DRAWZILLA said: I also see the new roof overbuild the existing roofs and have to delete the new roofs; I think it's been that way forever. I see. At least I'm not crazy then. Hopefully Chief can fix this overbuild situation at some point since going back to delete a bunch of roofs is rather inefficient. Thank you for your responses DRAWZILLA. In summarizing your comments & others' I understand: auto-build is pretty much a 1-time thing & then best to abandon it auto-build should therefore happen as late as possible in the design effort a house with multiple roofs will likely always require manual roof manipulation no matter what I should school myself in roof construction more - it's those odd-angled hip roof valleys & ridges that get me when attempting manually Link to comment Share on other sites More sharing options...
SHCanada2 Posted February 25 Share Posted February 25 11 hours ago, TheoryDesign said: I see. At least I'm not crazy then. Hopefully Chief can fix this overbuild situation at some point since going back to delete a bunch of roofs is rather inefficient I think it essentially has to be this way, as CA does not "know" that you do not want a roof there as some may want actually want it there. I suppose CA could try and keep track of roofs you delete after the auto build, and not rebuild those same roofs, but then you would still have to delete them, but only once. or it could assume any auto built roof that intersects a manual roof should not be built. I would think the latter would be significant effort as it would need to check the entire roof to see if there is any little portion of a manual roof intersecting it Link to comment Share on other sites More sharing options...
glennw Posted February 25 Share Posted February 25 16 hours ago, TheoryDesign said: auto-build is pretty much a 1-time thing & then best to abandon it Not correct - I build auto roofs right from the start auto-build should therefore happen as late as possible in the design effort Not correct - do them as early as possible a house with multiple roofs will likely always require manual roof manipulation no matter what Not correct - with a bit of practice you can get auto roofs going so that in most cases you do not have to do any manual roof editing I should school myself in roof construction more - it's those odd-angled hip roof valleys & ridges that get me when attempting manually Yes 1 Link to comment Share on other sites More sharing options...
