HumbleChief Posted February 5, 2025 Share Posted February 5, 2025 I have a couple of windows that will be demoed and put them on a separate layer with dashed lines to show that they will be demoed. The problem is only some of the window display gets the dashed lines. There's a dark line defining the outside of the window (see pic) Is there a way to get that solid line to be dashed as well? THANKS Link to comment Share on other sites More sharing options...
robdyck Posted February 5, 2025 Share Posted February 5, 2025 I'm not sure I can help without digging into your plan file. This is what I have displayed when I place the windows on a separate demo layer. Do you have the exterior casing layer turned on? Link to comment Share on other sites More sharing options...
Solution glennw Posted February 5, 2025 Solution Share Posted February 5, 2025 I think they are the "Use Interior Sill" and "Use Exterior Sill" and not the casings. 1 Link to comment Share on other sites More sharing options...
HumbleChief Posted February 6, 2025 Author Share Posted February 6, 2025 THANK YOU!! Will give both suggestions a try when time allows. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 6, 2025 Share Posted February 6, 2025 21 hours ago, glennw said: I think they are the "Use Interior Sill" and "Use Exterior Sill" and not the casings. I believe @glennwis correct and that you are seeing your sills, however, the display of those sills is controlled by the "Casings, Exterior" and "Casings, Interior" layers 1 Link to comment Share on other sites More sharing options...
HumbleChief Posted February 6, 2025 Author Share Posted February 6, 2025 21 hours ago, glennw said: I think they are the "Use Interior Sill" and "Use Exterior Sill" and not the casings. Unchecking the "use exterior sill" check box did the trick. Thanks Glenn. Link to comment Share on other sites More sharing options...
Renerabbitt Posted February 6, 2025 Share Posted February 6, 2025 On 2/5/2025 at 12:49 PM, HumbleChief said: I have a couple of windows that will be demoed and put them on a separate layer with dashed lines to show that they will be demoed. The problem is only some of the window display gets the dashed lines. There's a dark line defining the outside of the window (see pic) Is there a way to get that solid line to be dashed as well? THANKS Looks like you have sills turned on Link to comment Share on other sites More sharing options...
