thomhu Posted 14 hours ago Share Posted 14 hours ago Hello , I use Conestoga cabinets combined with our in-house custom shop for most of our kitchens. Is it possible to create or buy a library that would generate the correct nomenclature in the labels? For example, Chief will generate a cabinet label for a 24" base cabinet with butt doors as "B24". I would like it to match the naming system of Conestoga so it automatically reads "B24BD" in the schedule so it's easier for ordering. I don't need a style specific setup unless it's required - I just need the labels to change and show up in the schedule. Thanks, Thomas Huntington Huntington Construction LLC Chief x16 Windows 11 Link to comment Share on other sites More sharing options...
DBCooper Posted 11 hours ago Share Posted 11 hours ago Short answer, maybe. You might be able to use a custom macro to do this. Depends a bit on the naming conventions and whether you have all that info available through the name value pairs. For something as simple as what you are showing above, you could just modify the default label for base cabinets to use the automatic label and append the BD, as in %automatic_label%BD. For some special cases, you might be better off just setting the label manually and then saving the cabinet in your user library for reuse. Link to comment Share on other sites More sharing options...
GeneDavis Posted 11 hours ago Share Posted 11 hours ago Link to comment Share on other sites More sharing options...
GeneDavis Posted 11 hours ago Share Posted 11 hours ago Mr Google the AI bot directed me here, also. I get far better results chasing answers to Chieftalk topics using Google than the search here. Link to comment Share on other sites More sharing options...
MarkMc Posted 8 hours ago Share Posted 8 hours ago Might want to talk with @Joe_Carrick, he sells macros and last I knew he uses Consestoga. Link to comment Share on other sites More sharing options...
thomhu Posted 6 hours ago Author Share Posted 6 hours ago Thanks for all the replies! I appreciate your time. Will try these things out Link to comment Share on other sites More sharing options...
