thomhu Posted December 21, 2024 Share Posted December 21, 2024 Hello , I use Conestoga cabinets combined with our in-house custom shop for most of our kitchens. Is it possible to create or buy a library that would generate the correct nomenclature in the labels? For example, Chief will generate a cabinet label for a 24" base cabinet with butt doors as "B24". I would like it to match the naming system of Conestoga so it automatically reads "B24BD" in the schedule so it's easier for ordering. I don't need a style specific setup unless it's required - I just need the labels to change and show up in the schedule. Thanks, Thomas Huntington Huntington Construction LLC Chief x16 Windows 11 Link to comment Share on other sites More sharing options...
DBCooper Posted December 21, 2024 Share Posted December 21, 2024 Short answer, maybe. You might be able to use a custom macro to do this. Depends a bit on the naming conventions and whether you have all that info available through the name value pairs. For something as simple as what you are showing above, you could just modify the default label for base cabinets to use the automatic label and append the BD, as in %automatic_label%BD. For some special cases, you might be better off just setting the label manually and then saving the cabinet in your user library for reuse. Link to comment Share on other sites More sharing options...
GeneDavis Posted December 21, 2024 Share Posted December 21, 2024 Link to comment Share on other sites More sharing options...
GeneDavis Posted December 21, 2024 Share Posted December 21, 2024 Mr Google the AI bot directed me here, also. I get far better results chasing answers to Chieftalk topics using Google than the search here. Link to comment Share on other sites More sharing options...
MarkMc Posted December 21, 2024 Share Posted December 21, 2024 Might want to talk with @Joe_Carrick, he sells macros and last I knew he uses Consestoga. Link to comment Share on other sites More sharing options...
thomhu Posted December 21, 2024 Author Share Posted December 21, 2024 Thanks for all the replies! I appreciate your time. Will try these things out Link to comment Share on other sites More sharing options...
Joe_Carrick Posted December 22, 2024 Share Posted December 22, 2024 Yes, I do have a macro system to label using Conestoga nomenclature. Let me know if you want it and I can provide you with the price. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted December 23, 2024 Share Posted December 23, 2024 FWIW, I can add any Manufacturer nomenclature to this macro - if I have their catalog. Just as an example for Conestoga a 3 Drawer Base Cabinet would be B3D21 while Chief's standard Label is 3DB21. My macro typically is used in the "code" or any other OIP field which can be used in a schedule to display B3D21 Link to comment Share on other sites More sharing options...
GeneDavis Posted December 23, 2024 Share Posted December 23, 2024 How does it handle the various ways to do 3-drawer bases? There are three drawers all same height. There are one shallow over two deep. And two shallow over one deep. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted December 23, 2024 Share Posted December 23, 2024 19 minutes ago, GeneDavis said: How does it handle the various ways to do 3-drawer bases? There are three drawers all same height. There are one shallow over two deep. And two shallow over one deep. Conestoga nomenclature doesn't indicate drawer sizes. Generally they are standard sizes matching your 3rd example - but customization is possible. That would be handled in the Conestoga ordering system. I do have another set of macros for the door and drawer panel sizes: cabinet_panels - placed in the default label accumulates all panels into a global hash cabinet_panels_detail - placed in a custom field or the comment field displays the panel sizes, finish & type cabinet_panels_list - same as above but indicates the quantities so if there's more than one of the same it will indicate the qty. The above is all based on Chief's Cabinet NVPs Link to comment Share on other sites More sharing options...
Joe_Carrick Posted December 23, 2024 Share Posted December 23, 2024 I also have another macro that lists the drawer sizes for each cabinet. Link to comment Share on other sites More sharing options...
