Davidh-hhm Posted August 8, 2024 Share Posted August 8, 2024 Hopefully someone has some trick... I just updated to X16 and I have lost the mirror reflections in my Physical 3D view. They still show up in the Standard View.... Then when I switch to the Physical.... I tried creating a solid and applying the mirror material to it, but no dice. This is also happening with the blocks that I have downloaded. I've also made sure that the reflections are on: Would be much appreciated if someone has a fix for this. Thanks! Allison Link to comment Share on other sites More sharing options...
robdyck Posted August 8, 2024 Share Posted August 8, 2024 Can you post your plan? I can take a look right away... Link to comment Share on other sites More sharing options...
Davidh-hhm Posted August 8, 2024 Author Share Posted August 8, 2024 Link to comment Share on other sites More sharing options...
Davidh-hhm Posted August 8, 2024 Author Share Posted August 8, 2024 The file is way too big to post the file itself. Link to comment Share on other sites More sharing options...
robdyck Posted August 8, 2024 Share Posted August 8, 2024 Drop-box link, google drive link...if you don't want to post it here, send the link to me in a personal message. Link to comment Share on other sites More sharing options...
scottharris Posted August 8, 2024 Share Posted August 8, 2024 Did you try this setting in PBR? Link to comment Share on other sites More sharing options...
robdyck Posted August 8, 2024 Share Posted August 8, 2024 @scottharris Interesting...I just took a standard technique view with no reflections. Then toggled reflections on. Then switched technique to PBR. So far so good. Then opened Edit Active View and unchecked reflections. The reflections remained! The Toggle Reflections button has no checkmark, yet the reflection still exists. Clicking the Toggle Reflections button back to on (even though they are still visible) changes nothing. Toggling them off changes nothing...they persist and I no longer have control of reflections in this camera in PB. In standard technique, they still cooperate. Link to comment Share on other sites More sharing options...
Davidh-hhm Posted August 9, 2024 Author Share Posted August 9, 2024 Scott yes I did try that setting this morning. Sorry I was having trouble with my dropbox yesterday. https://www.dropbox.com/scl/fi/js21nyex4ufqs6zt1xgp7/Kornerstone-Kurelja_8_8_24.plan?rlkey=kcevb68z0rrumskfeu7ty89m2&st=fi499pag&dl=0 If anyone would help, that would be awesome. Thanks! Link to comment Share on other sites More sharing options...
scottharris Posted August 9, 2024 Share Posted August 9, 2024 David, it seems to work for me. Verify in your preferences your computer supports 'hardware ray tracing'. Otherwise, give our support group a call. Link to comment Share on other sites More sharing options...
Davidh-hhm Posted August 9, 2024 Author Share Posted August 9, 2024 I can get it to work with the raytracing...I'll be honest, that takes too long for what I am doing... It still will not reflect in the Physical View, (no raytracing). I checked the "hardware ray tracing" and mine says no.... I'm guessing that's the issue... I will call support shortly. Thanks for the help! Link to comment Share on other sites More sharing options...
KenL-sdd Posted August 9, 2024 Share Posted August 9, 2024 This worked for me as well. Link to comment Share on other sites More sharing options...
KenL-sdd Posted August 9, 2024 Share Posted August 9, 2024 What video card are you running? mac or windows? Link to comment Share on other sites More sharing options...
scottharris Posted August 9, 2024 Share Posted August 9, 2024 David, it should reflect w/o ray tracing. So, give us a call. Link to comment Share on other sites More sharing options...
BrianBeck Posted August 9, 2024 Share Posted August 9, 2024 There is an issue with mirror reflections in legacy PBR(no-ray tracing) in the 26.1 release. This will be fixed in the upcoming 26.2 update. 1 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted August 13, 2024 Share Posted August 13, 2024 Do you have reflections turned on in the camera DBX? Link to comment Share on other sites More sharing options...
