winterdd Posted May 31, 2024 Share Posted May 31, 2024 Anytime I have came across this I remembered you have to click the walls, (railing in this case), and check full gable for CA to generate the walls. Attic walls are turned on and still nothing is showing. Am I missing something here? "Flat ceiling" is unchecked, just simple lean too's. Link to comment Share on other sites More sharing options...
MPDesign Posted May 31, 2024 Share Posted May 31, 2024 Rob, My guess it is the railing wall type, try changing to your exterior wall type. 1 Link to comment Share on other sites More sharing options...
Doug_N Posted May 31, 2024 Share Posted May 31, 2024 If you post the plan I will take a look at it. 1 Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 31, 2024 Share Posted May 31, 2024 A coupla of causes: you did not make the carport a "room" and thus have no Room specification dialog controls OR you can go up to the "A" level of the carport and manually draw in the missing attic walls in the gable ends. There are several other causes posible but those are the most likely. DJP 1 Link to comment Share on other sites More sharing options...
winterdd Posted May 31, 2024 Author Share Posted May 31, 2024 Thanks guys, there is definitely something fishy going on because I tried to manually draw them in and nothing. I will try and load the plan file Link to comment Share on other sites More sharing options...
winterdd Posted May 31, 2024 Author Share Posted May 31, 2024 Manually drawn, pull some grips where they shot they shot thru the roof and they popped right in. Link to comment Share on other sites More sharing options...
Kbird1 Posted May 31, 2024 Share Posted May 31, 2024 29 minutes ago, winterdd said: Thanks guys, there is definitely something fishy going on because I tried to manually draw them in and nothing. I will try and load the plan file Do you have Attics Walls showing in ALL views? And Also have Auto Attic Walls on so they generate on their own? press ALT-Q shortcut and check M. Link to comment Share on other sites More sharing options...
winterdd Posted June 1, 2024 Author Share Posted June 1, 2024 1 hour ago, Kbird1 said: Do you have Attics Walls showing in ALL views? And Also have Auto Attic Walls on so they generate on their own? press ALT-Q shortcut and check M. Yep! everything turned on, that's what was confusing me as to why they weren't showing. Link to comment Share on other sites More sharing options...
