Buckeye50 Posted March 6, 2015 Share Posted March 6, 2015 Will earlier Chief Architect versions 9 & 10 run on Windows 7? Link to comment Share on other sites More sharing options...
NRST8TRKR Posted March 6, 2015 Share Posted March 6, 2015 Yes. Have a great weekend,Ken Link to comment Share on other sites More sharing options...
ChiefArchitect Posted March 6, 2015 Share Posted March 6, 2015 Unfortunately, versions earlier than X2 are not supported on Windows 7. Versions 9 and 10 were released in 2003 and 2005 respectively, and Windows 7 was not released until 2008, so there was no way to test those versions on that platform before their release. You can find a full list of supported Operating Systems for each version here: http://www.chiefarchitect.com/support/article/KB-00027/. Chief Architect Sales Link to comment Share on other sites More sharing options...
Kbird1 Posted March 6, 2015 Share Posted March 6, 2015 you could try WinXP compatibility mode in win7 and see if it works. M. Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 7, 2015 Share Posted March 7, 2015 I have versions 7-X1 installed on a hard drive that runs XP x32. Versions X2-X7 I run on a hard drive that runs Windows 7 x64 I intend to add another SSD hard drive on which I will run Windows 10 when it comes out. There is NO "fits all" solution out there, things run in an environment they were designed to run in and that is that, the rest are just ways to waste time. DJP Link to comment Share on other sites More sharing options...
Mainewood Posted March 7, 2015 Share Posted March 7, 2015 Will earlier Chief Architect versions 9 & 10 run on Windows 7? I am running 9.5 on windows xp using a "virtual machine" within my windows 7 operating system. I also run X6 on windows 7. Link to comment Share on other sites More sharing options...
mydog8it Posted March 7, 2015 Share Posted March 7, 2015 I couldn't get version 10 to run on Windows 7. It was years ago, so I can't remember why - just that it wouldn't work. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 7, 2015 Share Posted March 7, 2015 @Mainewood how well does the 3D work in a Virtual Drive , I thought that 3D acceleration wasn't enabled ? or is that just in the MS XP-Mode not the one you are using? Best bet is to just do a dual boot with XP and run it natively if needed. Link to comment Share on other sites More sharing options...
Mainewood Posted March 8, 2015 Share Posted March 8, 2015 CA 9.5 on virtual machine 2.bmp CA 9.5 on virtual machine.bmp Link to comment Share on other sites More sharing options...
Kbird1 Posted March 9, 2015 Share Posted March 9, 2015 Well it appear VMware Virtual machines work nice. Link to comment Share on other sites More sharing options...
FrancisUnderwood Posted November 4, 2015 Share Posted November 4, 2015 Well, i have just built a new Windows 7Ent in a VMWorkstation Pro 12 and it doesn't work for me. it returns the error below: Problem signature: Problem Event Name: APPCRASH Application Name: Chief Architect Premier X7.exe Application Version: 17.3.2.2 Application Timestamp: 55f786ce Fault Module Name: StackHash_6a33 Fault Module Version: 6.1.7601.19018 Fault Module Timestamp: 5609fdaf Exception Code: c0000374 Exception Offset: 000c3f83 OS Version: 6.1.7601.2.1.0.256.4 Locale ID: 1033 Additional Information 1: 6a33 Additional Information 2: 6a33e5234a546e320b533b6adfa78c37 Additional Information 3: b1ae Additional Information 4: b1aecce500c27123029ba7748f1142e8 Any ideas, folks? Thanks, Link to comment Share on other sites More sharing options...
Bob_Medvetz Posted November 4, 2015 Share Posted November 4, 2015 I am running Ver 10 on Windows 7 and Win 10 with no problems. Both are 32 bit versions of the OS. Link to comment Share on other sites More sharing options...
mydog8it Posted November 4, 2015 Share Posted November 4, 2015 I am running Ver 10 on Windows 7 and Win 10 with no problems. Both are 32 bit versions of the OS. My windows 7 is 64 bit and version 10 wouldn't work. Maybe that's the problem. Link to comment Share on other sites More sharing options...
Bob_Medvetz Posted November 4, 2015 Share Posted November 4, 2015 Joy, 64 bit may be the problem. Have you downloaded the Vista update to Ver 10? Here is the link to it. http://www.chiefarchitect.com/support/updates/update10fhist.html You will also have to update the Hardware lock too. Link to comment Share on other sites More sharing options...
mydog8it Posted November 4, 2015 Share Posted November 4, 2015 I had it working on vista, so I'm assuming I did, but it was years ago so I'm not sure. (I don't have a need for 10 now since I've already updated/redrawn all of my old plans. Just trying to help others troubleshoot...) Link to comment Share on other sites More sharing options...
