BCNABE Posted April 11, 2024 Share Posted April 11, 2024 Is there a way to adjust or lengthen the footing of a wall? In the attached image, at the top, I show a bearing wall with a footing and it looks correct - the footing goes beyond each end of the wall. But if I add a wall to make it "L" shaped and that wall segment is non-bearing (no footing) the footing on the bearing wall will only go to the center of the non-bearing wall when in reality it should go beyond it (the red line that I have noted). Link to comment Share on other sites More sharing options...
TeaTime Posted April 11, 2024 Share Posted April 11, 2024 Are these framed walls on Floor 1 marked as Foundation in order to build footings? If so, uncheck the Foundation setting on those walls. Instead, on the Structure panel check Bearing Wall / Create Wall/Footing Below. If you don't have a Foundation floor, you'll need to build one. These footings will still generate wrong around corners But the wall/footing can be adjusted on Floor 0 independently of the walls on Floor 1. Link to comment Share on other sites More sharing options...
BCNABE Posted April 12, 2024 Author Share Posted April 12, 2024 These are bearing walls in the basement, so I have the walls drawn on level 0 (foundation) and the walls marked as "foundation" in the dialog box. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 12, 2024 Share Posted April 12, 2024 1 Link to comment Share on other sites More sharing options...
robdyck Posted April 12, 2024 Share Posted April 12, 2024 On 4/11/2024 at 6:40 PM, BCNABE said: Is there a way to adjust or lengthen the footing of a wall? Expand Not a good one! The above methods will work, but I have found it much simpler to place the footings manually. I have a footing (made from a slab) saved to my library that has all the correct properties and elevations set so that I can place it in the plan, center it on the bearing walls, and then stretch it as needed. This is also especially helpful when you need to show a break in the footing at doorways or other portions to accommodate plumbing, etc. Currently, you can't break an auto-footing at a doorway. The only benefit to the auto-footing is that it is automatically centered. I don't need to update mine...I don't place them until I'm completing the final plan set. Another nice feature, is that my saved footing has a macro that auto-generates the text notes and it can report the footing length (if I see the need to include that information). And because it's a slab, it still fills correctly in section view. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 13, 2024 Share Posted April 13, 2024 We used to be able to adjust the footings independently a few versions back, but now you can't very easily. not sure why it went away. It was really easy to manipulate the footings for pads etc. Link to comment Share on other sites More sharing options...
