Cadwork22 Posted April 11, 2024 Share Posted April 11, 2024 I have a lean-to porch and a wall running north south how do I angle the top wall (grips aren't working at they the only option?) Link to comment Share on other sites More sharing options...
Doug_N Posted April 11, 2024 Share Posted April 11, 2024 Please post your plan file. Link to comment Share on other sites More sharing options...
MPDesign Posted April 11, 2024 Share Posted April 11, 2024 In the wall dbx, Roof section on the left, you can set the wall to ballon thru ceiling to get it to match the roof above. Link to comment Share on other sites More sharing options...
Cadwork22 Posted April 11, 2024 Author Share Posted April 11, 2024 Garrett.zip Link to comment Share on other sites More sharing options...
TeaTime Posted April 11, 2024 Share Posted April 11, 2024 Been bit by this one before, myself. It seems counter intuitive since you drew your roof planes manually, but you'll want to check Roof Over This Room in that room, otherwise Attic walls won't generate automatically to fill those spaces. Link to comment Share on other sites More sharing options...
Solution Doug_N Posted April 11, 2024 Solution Share Posted April 11, 2024 \ Link to comment Share on other sites More sharing options...
Cadwork22 Posted April 11, 2024 Author Share Posted April 11, 2024 Ha worked perfect thanks. Thanks, Michael Link to comment Share on other sites More sharing options...
TeaTime Posted April 11, 2024 Share Posted April 11, 2024 For what it's worth, Doug's fix worked because defining it as a specific room type forces Roof Over This Room to be checked. Our fixes were essentially the same. It's worth remembering that Roof Over This Room is not just for auto roof plane generation, it needs to be on for proper roof supporting structural walls to generate. 1 Link to comment Share on other sites More sharing options...
Cadwork22 Posted April 12, 2024 Author Share Posted April 12, 2024 Good to know, I think by default it is usually on Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 13, 2024 Share Posted April 13, 2024 also those end walls really should be balloon frame thru ceiling, no separate attic walls. Link to comment Share on other sites More sharing options...
Doug_N Posted April 14, 2024 Share Posted April 14, 2024 On 4/13/2024 at 11:31 AM, DRAWZILLA said: also those end walls really should be balloon frame thru ceiling, no separate attic walls. Good point Perry, True for any load bearing or external walls subject to wind pressure, but ok for interior walls. Link to comment Share on other sites More sharing options...
