winterdd Posted March 20, 2024 Share Posted March 20, 2024 I have my labels set up like I want. Working plan is right but in electrical they are still uppercase and bigger font. I have messed with settings for a half hour and cannot figure it out. I can't stand minor things like this holding me up. working plan view electrical plan view Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 20, 2024 Share Posted March 20, 2024 check your text style setting in the correct layer those fixtures are on. 1 Link to comment Share on other sites More sharing options...
winterdd Posted March 20, 2024 Author Share Posted March 20, 2024 7 minutes ago, DRAWZILLA said: check your text style setting in the correct layer those fixtures are on. it all still looks right to me. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 20, 2024 Share Posted March 20, 2024 try opening the text style to adjust it, if you haven't already done so. 1 Link to comment Share on other sites More sharing options...
robdyck Posted March 20, 2024 Share Posted March 20, 2024 28 minutes ago, winterdd said: it all still looks right to me. That's why you have the problem:) It's not right and you're currently not finding the correct text style. Make sure you are checking the text style for the layer set that is used in your electrical plan. A simple way to find this: in the electrical plan, single click a fixture. Select the Object Properties tool from the bottom. Change the text style for the Fixture, Labels layer. Or post your plan and I'll show you exactly what to do. 1 Link to comment Share on other sites More sharing options...
DBCooper Posted March 20, 2024 Share Posted March 20, 2024 Select one of the objects, like the soaker tub. Look in the ALDO. What text style is it using for the labels? Now switch to the other saved plan view. Do the same thing. What you will probably find is that it is not using the same text style in both layer sets. The OOB defaults use "default label style" for the working plan view and "1/4" text style" in the electrical plan view. 1 Link to comment Share on other sites More sharing options...
CharlesVolz Posted March 20, 2024 Share Posted March 20, 2024 Howdy Rob, Look here in your elec symbols DBX: 1 Link to comment Share on other sites More sharing options...
winterdd Posted March 20, 2024 Author Share Posted March 20, 2024 Am I in the right area guys? haha this one is getting me..... been a while since I came across something like this I am just not getting. Link to comment Share on other sites More sharing options...
winterdd Posted March 20, 2024 Author Share Posted March 20, 2024 or this......... Link to comment Share on other sites More sharing options...
winterdd Posted March 20, 2024 Author Share Posted March 20, 2024 Found it, dang, previous versions OOB never made me dig this deep. Thanks guys, it was on 1/4" defaults Link to comment Share on other sites More sharing options...
DBCooper Posted March 20, 2024 Share Posted March 20, 2024 Quote What you will probably find is that it is not using the same text style in both layer sets. The OOB defaults use "default label style" for the working plan view and "1/4" text style" in the electrical plan view. That's what I thought. Link to comment Share on other sites More sharing options...
CharlesVolz Posted March 20, 2024 Share Posted March 20, 2024 This or this Or custom. Link to comment Share on other sites More sharing options...
