ArmanChahal Posted February 17, 2024 Share Posted February 17, 2024 Is there a way to create a recessed light which actually cut a hole and flush mount with the ceiling. Attached is the light I want to use. This is what's happening right now with options set to ceiling mount and flush mount checked. Link to comment Share on other sites More sharing options...
DBCooper Posted February 18, 2024 Share Posted February 18, 2024 No. Lights will only sit on the ceiling surface and can't cut a hole in it. You might be able to get what you want by making a custom hole in ceiling though. Link to comment Share on other sites More sharing options...
ArmanChahal Posted February 20, 2024 Author Share Posted February 20, 2024 I thought so. I did tried making a hole in the ceiling but then the light got attached to the roof plane. I will try to make something manually. Thanks for the advise. Link to comment Share on other sites More sharing options...
TeaTime Posted February 20, 2024 Share Posted February 20, 2024 Try pairing the Hole in Ceiling with a custom Ceiling Plane at 0" pitch. Link to comment Share on other sites More sharing options...
ArmanChahal Posted February 21, 2024 Author Share Posted February 21, 2024 Hey thanks for the effort. But there is another floor on top. Link to comment Share on other sites More sharing options...
VHampton Posted February 21, 2024 Share Posted February 21, 2024 The tray ceiling tool can offer varying depths. The required ceiling "niche" can be as minimal as 2" if necessary. What this does however is "drop" the entire ceiling while leaving the floor components above untouched. (If this is for modeling purposes only, then perhaps it's a viable option.) The cross section however will show the newly added ceiling thickness. Option B... Change the "z" axis offset for the custom light fixture. Calibrate the input so that the flange passes through the sheetrock layer. This might require having to "flatten"/reduce the depth of the symbol to get the bulbs to poke through as well. Link to comment Share on other sites More sharing options...
Chief_Content Posted Friday at 01:12 PM Share Posted Friday at 01:12 PM New to X17 is the ability to set up your 3D lighting (and any other 3D Symbol) to automatically cut holes in walls, floors, ceilings and roofs! We've provided a new catalog specifically for different sizes of recessed lighting objects - you can download here. To your original question, @ArmanChahal, you should now in X17 be able to set up your light fixture to behave as desired! 2 Link to comment Share on other sites More sharing options...
GeneDavis Posted Saturday at 01:13 PM Share Posted Saturday at 01:13 PM OMG thanks Chief! I recall making the suggestion for this, which is particularly huge for users who do lots of kitchens and need photoreal renderings. 1 Link to comment Share on other sites More sharing options...
