winterdd Posted February 13, 2024 Share Posted February 13, 2024 Guys, I was emailed a plan file from a local builder needing me to clean up their model and do renderings for them. My question is why would this be missing (circled below). Would someone have had to delete them. I believe this came from X15 because when I saved it no warning came up about a previous version. Just trying to see how to revise this and switch between the framing and electrical and such. The home is fully modeled. Link to comment Share on other sites More sharing options...
GeneDavis Posted February 13, 2024 Share Posted February 13, 2024 The user must not understand how to use SPVs, and works from a template in which there are none. Ask them. 1 Link to comment Share on other sites More sharing options...
SNestor Posted February 13, 2024 Share Posted February 13, 2024 Import your saved plan views from your template into this plan... 2 Link to comment Share on other sites More sharing options...
winterdd Posted February 13, 2024 Author Share Posted February 13, 2024 On 2/13/2024 at 3:58 PM, GeneDavis said: The user must not understand how to use SPVs, and works from a template in which there are none. Ask them. Expand It appears they had AutoCad in mind when doing the design and set up extra layers to turn on and off between the groups. I get it, but boy is it easier with CA setup. Link to comment Share on other sites More sharing options...
winterdd Posted February 13, 2024 Author Share Posted February 13, 2024 On 2/13/2024 at 4:06 PM, SNestor said: Import your saved plan views from your template into this plan... Expand could you claify that? Sounds interesting. Link to comment Share on other sites More sharing options...
DBCooper Posted February 13, 2024 Share Posted February 13, 2024 Based on the walls being yellow, my guess is that it was started with a very old version of Chief that did not have saved plan views. It was probably brought forward and then saved in X15 without ever adding/importing any saved plan views. You could import the saved plan views you want using "file/import". You could also just create them on the fly as needed by setting up the views you want to save and then saving them. This is super easy in principle but if the plan doesn't have proper layer sets or default sets it can be a bit of a pain. You could also just "old school" it and not use saved plan views but if you have never worked this way before you probably won't like it. 1 Link to comment Share on other sites More sharing options...
GeneDavis Posted February 14, 2024 Share Posted February 14, 2024 @winterdd, does "clean it up" mean finish it for them including con docs? Is this a one-off custom or is it to be a stock build for them. Are you in it for con docs also? 1 Link to comment Share on other sites More sharing options...
winterdd Posted February 14, 2024 Author Share Posted February 14, 2024 On 2/14/2024 at 2:14 PM, GeneDavis said: @winterdd, does "clean it up" mean finish it for them including con docs? Is this a one-off custom or is it to be a stock build for them. Are you in it for con docs also? Expand it is everything you just mentioned. Link to comment Share on other sites More sharing options...
Gawdzira Posted February 14, 2024 Share Posted February 14, 2024 Not using SPV's in CA begs the question "Do you even CADD bro?" 2 Link to comment Share on other sites More sharing options...
SNestor Posted February 14, 2024 Share Posted February 14, 2024 Rob - quick video on importing saved plan views; Rob - Import Saved Plan Views - Watch Video 1 1 Link to comment Share on other sites More sharing options...
winterdd Posted February 14, 2024 Author Share Posted February 14, 2024 On 2/14/2024 at 6:07 PM, SNestor said: Rob - quick video on importing saved plan views; Rob - Import Saved Plan Views - Watch Video Expand That is a very smart way, thanks Steve. Link to comment Share on other sites More sharing options...
