ChiefChrissy Posted November 29, 2023 Share Posted November 29, 2023 How can I extend the brick wall to the ceiling in the picture below? It wants to stop at the first ceiling but I need to to go to the double height space. Link to comment Share on other sites More sharing options...
SNestor Posted November 29, 2023 Share Posted November 29, 2023 Open the wall, on the structure tab select “ballon through ceiling”. Link to comment Share on other sites More sharing options...
ChiefChrissy Posted November 29, 2023 Author Share Posted November 29, 2023 I did that and it only worked for one of the walls but now I cannot change the material on it. Any other suggestions or ideas why this might be happening? Link to comment Share on other sites More sharing options...
GeneDavis Posted November 29, 2023 Share Posted November 29, 2023 Try posting the plan file. Link to comment Share on other sites More sharing options...
Kbird1 Posted November 29, 2023 Share Posted November 29, 2023 37 minutes ago, ChiefChrissy said: I did that and it only worked for one of the walls but now I cannot change the material on it. Any other suggestions or ideas why this might be happening? Press Alt-Q on your keyboard ( General Wall Defaults) and see if Auto Build Attic Walls is on...... M. Link to comment Share on other sites More sharing options...
TeaTime Posted November 29, 2023 Share Posted November 29, 2023 Start off simple: in the Camera view, is your "Walls, Attic" layer on? I've put myself in a tizzy before not realising that layer was off in my camera view layer set. Next thought: are those Roof Planes or Ceiling Planes? Because walls won't build up to Ceiling Planes, but they will to Roof Planes. Link to comment Share on other sites More sharing options...
ChiefChrissy Posted December 1, 2023 Author Share Posted December 1, 2023 Thank you, they are ceiling planes which explains that problem. I switched to roof planes and that worked however I cannot change the finish of the wall above the the intermediary ceiling. its coming in as wood? any thoughts on that?? Link to comment Share on other sites More sharing options...
GeneDavis Posted December 1, 2023 Share Posted December 1, 2023 @ChiefChrissyeven when using Chief for just interiors, it is best to model roofs over the room or rooms. You have now learned that walls build to roofs, and if you are using Chief to produce renderings, roofs work to make lighting more realistic. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 1, 2023 Share Posted December 1, 2023 58 minutes ago, GeneDavis said: and if you are using Chief to produce renderings, roofs work to make lighting more realistic. It's also a good Idea to let Chief build a Auto foundation for the same reason ...to help stop light bleed especially 2 hours ago, ChiefChrissy said: any thoughts on that?? No Pics and no Plan make that a guessing game..... Mick. Link to comment Share on other sites More sharing options...
