DeLayDesign Posted September 11, 2023 Share Posted September 11, 2023 Hey folks - has anyone experienced a random 1/8" being added to your dimension strings? No matter what I do to try to adjust the dimensions it keeps adding in 1/8" to my dimensions. What's even more strange is when I try to adjust the dimension to 10'6" even, and click on the dimension that says 10'6.125" chief is telling me it is actually 10'6". I've tried moving the connections, moving the walls... and nothing changes. Link to comment Share on other sites More sharing options...
DBCooper Posted September 11, 2023 Share Posted September 11, 2023 It might have to do with rounding. Depending on your settings, Chief might show a different value for the overall dimension so that all of the inner dimensions will actually add up. You might want to check each of the other dimensions to see if they are actually what you think they should be. If that doesn't help, then post the plan. Link to comment Share on other sites More sharing options...
Chopsaw Posted September 11, 2023 Share Posted September 11, 2023 Maybe set your grid snaps to 1/8" and see if that helps other wise you may need to post the plan. If your grid snaps are set to 1" and you try a 1/8" adjustment it may not allow it. Or turn off snaps temporarily. Link to comment Share on other sites More sharing options...
DeLayDesign Posted September 11, 2023 Author Share Posted September 11, 2023 I checked the 'rounding' it's set to a value of 1/8" and each cabinet is an exact width (3" increments)... Even if I try to move the wall to the dimension I want (10'-6"), Chief says it's 10'-6" in the dimension dialog; but the dimension keeps saying it's 10'6.125". I ended up overwriting the text so it read correctly, but something strange is definitely happening. I have also submitted a ticket to chief. Link to comment Share on other sites More sharing options...
basketballman Posted September 11, 2023 Share Posted September 11, 2023 What happens if you set your Primary Format to 0 ? Link to comment Share on other sites More sharing options...
DeLayDesign Posted September 11, 2023 Author Share Posted September 11, 2023 6 minutes ago, basketballman said: What happens if you set your Primary Format to 0 ? Changing it to zero would make all fractions go away; which it does. Link to comment Share on other sites More sharing options...
DBCooper Posted September 11, 2023 Share Posted September 11, 2023 Looking at your picture above, the math adds up: 4' 3" + 2' 6" + 3' 9 1/8" = 10' 6 1/8" Your cabinets may be on 3" increments but this doesn't mean they are positioned accurately. Maybe you have some small gaps or even overlaps somewhere along the row. Or, maybe your appliances aren't sized or positioned accurately. You might want to also check to see if both the 2' 6" or the 3' 9 1/8" dimensions are exact. My guess is that this is just a problem with how you have laid things out. Link to comment Share on other sites More sharing options...
robdyck Posted September 11, 2023 Share Posted September 11, 2023 There's no plan attached. Was that overlooked? Link to comment Share on other sites More sharing options...
Chopsaw Posted September 12, 2023 Share Posted September 12, 2023 10 hours ago, DeLayDesign said: I checked the 'rounding' it's set to a value of 1/8" I would try changing that to 1/16" and see what happens. Unfortunately Grid Rounding can show an error as much as you have your Smallest Fraction set to in my testing under some situations, so you may want to eliminate that possibility by switching to Distance Rounding and see if that resolves it, or part of it. Again these are all guesses without the plan file.... Surely you can clip a kitchen island out of a plan file without breaching client confidentiality. Or wait a week for tech support to respond. I have had quite a few responses from tech recently that just say "why not post it on the forum". Link to comment Share on other sites More sharing options...
