kwhitt Posted August 14, 2023 Share Posted August 14, 2023 I may have found another issue with the latest release of X15. I am creating a cross section and want to display “Cabinets, Custom Backsplashes” only so that I can send off for a quote – see attached video. As you can see the screen will not update with a change in the layer’s visibility. On an individual basis there is no problem; however, when I select all layers to turn them all off and then select a couple that I want visible, nothing appears. I've been using this technique for years with no problems. Can anyone confirm this? 14.08.2023_08.05.21_REC.mp4 Link to comment Share on other sites More sharing options...
GeneDavis Posted August 14, 2023 Share Posted August 14, 2023 Can't comment without the plan. Post it. Link to comment Share on other sites More sharing options...
kwhitt Posted August 14, 2023 Author Share Posted August 14, 2023 On 8/14/2023 at 12:28 PM, GeneDavis said: Can't comment without the plan. Post it. Expand The plan is too large to post here. I can upload to DB and provide a link. Link to comment Share on other sites More sharing options...
kwhitt Posted August 14, 2023 Author Share Posted August 14, 2023 On 8/14/2023 at 12:28 PM, GeneDavis said: Can't comment without the plan. Post it. Expand Here's the download link: https://www.dropbox.com/scl/fo/8t8k1pusihbbw130kn9nt/h?rlkey=h0nuxj7mlfz5cg3p1664wlh11&dl=0 Thanks, Kevin Link to comment Share on other sites More sharing options...
kwhitt Posted August 14, 2023 Author Share Posted August 14, 2023 This is a basement level. When I turn off the layers one by one I find that the layer "Foundation" turns everything off on this floor. I guess this was the problem. Link to comment Share on other sites More sharing options...
DBCooper Posted August 14, 2023 Share Posted August 14, 2023 Quote I find that the layer "Foundation" turns everything off on this floor. Expand Been bitten by that one myself. The "rooms" layer is another one that will get you. 1 Link to comment Share on other sites More sharing options...
ValleyGuy Posted August 15, 2023 Share Posted August 15, 2023 I've had the same issue a couple of times...."rooms" was the culprit that needed to be checked once and "CAD Default" was the other. 1 Link to comment Share on other sites More sharing options...
kwhitt Posted August 15, 2023 Author Share Posted August 15, 2023 On 8/15/2023 at 12:19 AM, ValleyGuy said: I've had the same issue a couple of times...."rooms" was the culprit that needed to be checked once and "CAD Default" was the other. Expand I didn't even realize you could turn off an entire floor. Link to comment Share on other sites More sharing options...
TeaTime Posted August 15, 2023 Share Posted August 15, 2023 On 8/15/2023 at 11:31 AM, kwhitt said: I didn't even realize you could turn off an entire floor. Expand Only "Foundation", it's special. Link to comment Share on other sites More sharing options...
