JKEdmo Posted July 17, 2023 Share Posted July 17, 2023 I'm a little perplexed by the Object Eyedropper tool and it's abilities. I was just now trying to match / convert an arrowhead of a room leader from arrow to dot style. This to me seems about as basic a challenge for such a tool... But, the tool does not seem to work for me. Digging deeper, I see that the "properties to load" panel does not have any arrowhead properties, so maybe that's why the arrowhead does not change: From what I have read, the tool seems pretty powerful and detailed... Anyhow, two questions: 1) Am I misusing the tool and I just need to understand it better? 2) And related to this -- does Chief have a true "match ALL properties" tool that works? Thanks, Jim Link to comment Share on other sites More sharing options...
DBCooper Posted July 17, 2023 Share Posted July 17, 2023 1) I have found that "match properties" does not include all properties. I think Chief has said in the past that they will add more properties over time based on what people ask for. You might want to send them a feature request for things like this you want included, like arrowheads. 2) Yes, it's called copy/paste. Probably not going to help in this case though because you don't really want to match all properties. For cases like this, I would just select both lines and set the arrowheads the same. I would also make sure I had my defaults set up so that I would get the arrowheads I wanted from the start. Link to comment Share on other sites More sharing options...
JKEdmo Posted July 17, 2023 Author Share Posted July 17, 2023 18 minutes ago, DBCooper said: I have found that "match properties" does not include all properties. I think Chief has said in the past that they will add more properties over time based on what people ask for. You might want to send them a feature request for things like this you want included, like arrowheads. Thanks DB for your quick reply and insight. Jim Link to comment Share on other sites More sharing options...
Joe_Carrick Posted July 17, 2023 Share Posted July 17, 2023 Actually using the "Match Properties" tool works. OTOH, the "Object Painter" tool really should match the "Arrow Style". Submit a request. Link to comment Share on other sites More sharing options...
Renerabbitt Posted July 17, 2023 Share Posted July 17, 2023 22 minutes ago, JKEdmo said: Thanks DB for your quick reply and insight. Jim This specifically is the default arrow style for your active view, just as fast to change the default. 3 Clicks Link to comment Share on other sites More sharing options...
JKEdmo Posted July 17, 2023 Author Share Posted July 17, 2023 8 minutes ago, Joe_Carrick said: OTOH, the "Object Painter" tool really should match the "Arrow Style". Submit a request. Thanks Joe. Went to do it, but you beat me to it! Jim Link to comment Share on other sites More sharing options...
JKEdmo Posted July 17, 2023 Author Share Posted July 17, 2023 5 minutes ago, Renerabbitt said: This specifically is the default arrow style for your active view, just as fast to change the default. 3 Clicks Yes, except I want to keep my default as a normal arrow head. I occassionally use the leader with a dot style head for the room tags I place outside a room. Link to comment Share on other sites More sharing options...
Renerabbitt Posted July 17, 2023 Share Posted July 17, 2023 2 minutes ago, JKEdmo said: Yes, except I want to keep my default as a normal arrow head. I occassionally use the leader with a dot style head for the room tags I place outside a room. still as many clicks to change back..think of it as a tool..edit view, switch default..draw, then do it again. Even faster if you just make a SPV with that arrow default, then you can hover over SPVs, mouse wheel down once and have the second arrow style defaulted..requires a new layer set and SPV Link to comment Share on other sites More sharing options...
JKEdmo Posted July 17, 2023 Author Share Posted July 17, 2023 10 minutes ago, Renerabbitt said: still as many clicks to change back..think of it as a tool..edit view, switch default..draw, then do it again. Even faster if you just make a SPV with that arrow default, then you can hover over SPVs, mouse wheel down once and have the second arrow style defaulted..requires a new layer set and SPV Don't understand off hand, but I'll give the technique a try. I have some homework to do... Jim Link to comment Share on other sites More sharing options...
ACADuser Posted September 10, 2023 Share Posted September 10, 2023 The "Match Properties" tool need some upgrades! First on my list would be a SELECT button so the user can select objects to filter from, not the entire visible objects. Second would be all or most of the object properties. Like arrow heads, this is a PITA for me too! Also the default text height of the object so you could select all of the Rtext with 5" default text height. Link to comment Share on other sites More sharing options...
Rickster Posted August 6, 2024 Share Posted August 6, 2024 This is slightly off topic but how do I change the default arrowhead for ever more? Sorry I'm using X6. Link to comment Share on other sites More sharing options...
