GeneDavis Posted July 4, 2023 Share Posted July 4, 2023 In X15, what would prevent the framing, the joists, rims, beams, and posts, from reporting to the material list? The plan file is over 100 Mb, so let's see if this works. https://drive.google.com/file/d/13xxAp8cihYuspqJNhKZkoWCjn6cmb8Xh/view?usp=drive_link Link to comment Share on other sites More sharing options...
Kbird1 Posted July 4, 2023 Share Posted July 4, 2023 On 7/4/2023 at 3:01 PM, GeneDavis said: The plan file is over 100 Mb, so let's see if this works. https://drive.google.com/file/d/13xxAp8cihYuspqJNhKZkoWCjn6cmb8Xh/view?usp=drive_link Expand Nope , nobody has access it seems...... M. Link to comment Share on other sites More sharing options...
DG1949 Posted July 4, 2023 Share Posted July 4, 2023 If I try to get a material list by selecting the deck "room",, I get nada. If I calculate all floors it shows up under I.D.: Decks-Walks. But at least I can shut all else off and isolate the deck mats that way. Link to comment Share on other sites More sharing options...
GeneDavis Posted July 4, 2023 Author Share Posted July 4, 2023 On 7/4/2023 at 4:47 PM, DG1949 said: If I try to get a material list by selecting the deck "room",, I get nada. If I calculate all floors it shows up under I.D.: Decks-Walks. But at least I can shut all else off and isolate the deck mats that way. Expand My file? You get the 4x4, the 4x8, the 2x8 framing all to report? Show me a screen cap. Link to comment Share on other sites More sharing options...
DG1949 Posted July 4, 2023 Share Posted July 4, 2023 On 7/4/2023 at 5:14 PM, GeneDavis said: My file? Expand No, sorry, Gene. I also could not access your file. I just did what I did in one of my own. Do you get no "Decks-Walks" materials if you generate a list for all floors? Link to comment Share on other sites More sharing options...
GeneDavis Posted July 4, 2023 Author Share Posted July 4, 2023 OK I'm a dummy when it comes to this. I changed the file in Google Drive so "anyone" can access it. https://drive.google.com/file/d/13xxAp8cihYuspqJNhKZkoWCjn6cmb8Xh/view?usp=sharing Link to comment Share on other sites More sharing options...
robdyck Posted July 4, 2023 Share Posted July 4, 2023 Gene, have you tried turning that layer on for the Materials List Layer set? (Framing, Deck at rear). Give it a shot and see what happens! Link to comment Share on other sites More sharing options...
GeneDavis Posted July 4, 2023 Author Share Posted July 4, 2023 The layer is on. Any of the framing members can be selected and opened for spec. Here is how the material list is reporting. Up higher in the material list, every single framing member in floors, walls, and roofs is reporting. Link to comment Share on other sites More sharing options...
DG1949 Posted July 4, 2023 Share Posted July 4, 2023 As soon as I re-built the framing, I got this: So it must be related to manual framing. Disconnects evidently. Link to comment Share on other sites More sharing options...
GeneDavis Posted July 4, 2023 Author Share Posted July 4, 2023 The framing was built auto, then edited. All the rims got changed because Chief built them a 1.125 engineered lumber. I edited the joist layout and added the blocking for the railing post anchors. That's all. Link to comment Share on other sites More sharing options...
Solution robdyck Posted July 4, 2023 Solution Share Posted July 4, 2023 On 7/4/2023 at 8:25 PM, GeneDavis said: The framing was built auto, then edited. All the rims got changed because Chief built them a 1.125 engineered lumber. I edited the joist layout and added the blocking for the railing post anchors. That's all. Expand In the plan you made available, the layer I mentioned was not on in the Materials List layer set. Link to comment Share on other sites More sharing options...
GeneDavis Posted July 4, 2023 Author Share Posted July 4, 2023 Thanks! I had no idea there was a Materials List Layer Set. I though the way what was reported to the ML was via that dialog that has categories. 1 Link to comment Share on other sites More sharing options...
robdyck Posted July 4, 2023 Share Posted July 4, 2023 On 7/4/2023 at 9:28 PM, GeneDavis said: Thanks! I had no idea there was a Materials List Layer Set. I though the way what was reported to the ML was via that dialog that has categories. Expand In previous versions, the Layer Display dialog had an 'M' column that could be checked to include layers in materials lists, but of course those could be altered for every layer set, which increased the chance of user error. This was updated to a single layer set just for controlling materials list reporting. You could make copies of that layer set for specific purposes. Feel free to mark that post as 'solved'! Link to comment Share on other sites More sharing options...
