JKEdmo Posted June 15, 2023 Share Posted June 15, 2023 Good morning, Maybe more of a question directed to builders / framers, but would you have any buildability concerns about a wood framed stair designed w/ maximum allowable riser height? To explain, I designed my stairs on a project with maximum allowable 7-3/4" riser height (California). Code does permit a 3/8" tolerance between min./max. risers. Normally, I'd design in some tolerance wiggle room on my floor-to-floor height, but overlooked this and I'd prefer just to leave as designed as I'm pretty far along. Thoughts? Thanks again, Jim Link to comment Share on other sites More sharing options...
ACADuser Posted June 15, 2023 Share Posted June 15, 2023 Here in Florida 7-3/4 max for residential & 7" max for commercial. The +/- 3/8 will not allow your to exceed 7-3/4", only -3/8. This is why I avoid 7-3/4 & it is uncomfortable. Also the 10" tread is unconformable as well. This can be tricky if the finished floors change from your specified thickness. 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 15, 2023 Share Posted June 15, 2023 There's a formula for comfortable risers/treads: 2R+T = 24"-26" I prefer to keep the risers < 7" and I adjust the treads so that the result of the formula = 25". Generally my risers will be about 6.75" and the treads will be 11.5" but it really depends on the floor to floor height. 1 Link to comment Share on other sites More sharing options...
para-CAD Posted June 15, 2023 Share Posted June 15, 2023 From step to step only ⅛” variation is allowed with a max of ⅜” cumulatively over the entire stairway. I’ve cut stringers at code limits, but I don’t like to be that close. And that is a pretty steep stairway to transit. If you can add a step, passing inspection is much more easy. https://www.dropbox.com/s/k5zawo1rrm2agfx/RISER MATRIX.pdf?dl=0 2 Link to comment Share on other sites More sharing options...
JKEdmo Posted June 15, 2023 Author Share Posted June 15, 2023 46 minutes ago, ACADuser said: The +/- 3/8 will not allow your to exceed 7-3/4", only -3/8. Yes, I think your code interpretation is correct. I missed that. Good to know. 31 minutes ago, Joe_Carrick said: There's a formula for comfortable risers/treads: 2R+T = 24"-26" Thanks! 29 minutes ago, para-CAD said: I’ve cut stringers at code limits, but I don’t like to be that close. Thanks for your realistic "in the field" input! I will revisit this. You've all convinced me to add a tread. Jim Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 17, 2023 Share Posted June 17, 2023 i think about the old days when we had 9" risers for residential. Spiral secondary stairs still have large risers allowable. Link to comment Share on other sites More sharing options...
JKEdmo Posted June 17, 2023 Author Share Posted June 17, 2023 41 minutes ago, DRAWZILLA said: i think about the old days when we had 9" risers for residential. Spiral secondary stairs still have large risers allowable. I seem to remember 8" treads / 9" risers being allowable in California up until the 90s? Seems like a distant memory... Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 17, 2023 Share Posted June 17, 2023 1 hour ago, DRAWZILLA said: Spiral secondary stairs still have large risers allowable. If that wasn't so it would be difficult to maintain head height clearance. 1 Link to comment Share on other sites More sharing options...
GeneDavis Posted June 30, 2023 Share Posted June 30, 2023 I try for 7.5 or a little less, and go with tread depth of 10.5. Using an old standard from memory rise plus run equals 18, I'm right on with that config. Using Joe's 2R + T = 24 to 26, my numbers come to 25.5, not ideal, but OK. When there is plenty of space I like to go down to 7.25 with 10.75 treads. There is a huge diff in comfort ascending a stair that is 7.25 x 10.75 versus a 7.75 x 10. The problem with the treads wider than a 10" run, if it's for a hardwood staircase, typically 1" oak treads, is that the stair parts suppliers make the treads for the 10" run size, and not wider. The builder has to get treads from a local millwork shop custom sized to the 10+ inch run. 1 Link to comment Share on other sites More sharing options...
JKEdmo Posted June 30, 2023 Author Share Posted June 30, 2023 2 hours ago, GeneDavis said: I try for 7.5 or a little less, and go with tread depth of 10.5. Gene, Thanks for your insight. Jim Link to comment Share on other sites More sharing options...
