Max. Stair Riser Height - Builder Question
Good morning,
Maybe more of a question directed to builders / framers, but would you have any buildability concerns about a wood framed stair designed w/ maximum allowable riser height?
To explain, I designed my stairs on a project with maximum allowable 7-3/4" riser height (California).  Code does permit a 3/8" tolerance between min./max. risers.  Normally, I'd design in some tolerance wiggle room on my floor-to-floor height, but overlooked this and I'd prefer just to leave as designed as I'm pretty far along.
Thoughts?
Thanks again,
Jim
Here in Florida 7-3/4 max for residential & 7" max for commercial.
The +/- 3/8 will not allow your to exceed 7-3/4", only -3/8.
This is why I avoid 7-3/4  & it is uncomfortable. Also the 10" tread is unconformable as well.
This can be tricky if the finished floors change from your specified thickness.
There's a formula for comfortable risers/treads:
  • 2R+T = 24"-26"
I prefer to keep the risers < 7" and I adjust the treads so that the result of the formula = 25".
Generally my risers will be about 6.75" and the treads will be 11.5" but it really depends on the floor to floor height.
From step to step only ⅛” variation is allowed with a max of ⅜” cumulatively over the entire stairway.
I’ve cut stringers at code limits, but I don’t like to be that close.  And that is a pretty steep stairway to transit.
If you can add a step, passing inspection is much more easy.
https://www.dropbox.com/s/k5zawo1rrm2agfx/RISER MATRIX.pdf?dl=0
  • Upvote 2
Yes, I think your code interpretation is correct.  I missed that.  Good to know.
  • 2R+T = 24"-26"
Thanks!
Thanks for your realistic "in the field" input!
I will revisit this.  You've all convinced me to add a tread.
Jim
41 minutes ago, DRAWZILLA said:
i think about the old days when we had 9" risers for residential. Spiral secondary  stairs still have large risers allowable.
I seem to remember 8" treads / 9" risers being allowable in California up until the 90s?  Seems like a distant memory...
  • 2 weeks later...
I try for 7.5 or a little less, and go with tread depth of 10.5.  Using an old standard from memory rise plus run equals 18, I'm right on with that config.
Using Joe's 2R + T = 24 to 26, my numbers come to 25.5, not ideal, but OK.
When there is plenty of space I like to go down to 7.25 with 10.75 treads.  There is a huge diff in comfort ascending a stair that is 7.25 x 10.75 versus a 7.75 x 10.
The problem with the treads wider than a 10" run, if it's for a hardwood staircase, typically 1" oak treads, is that the stair parts suppliers make the treads for the 10" run size, and not wider.  The builder has to get treads from a local millwork shop custom sized to the 10+ inch run.
