Interactive Floor Plan / Destination Point to 360 Panoramas
Ange822
6 minutes ago, Chopsaw said:
Sure.  Particularly with X15.  Just keep track of the locations when you create your panoramas and then post a hotlink to the viewer in your plan view.
Thank you for your response. Do you have an example of this? How would I hotlink it, would the transition be smooth? I currently have x14 but am looking into x15.
It can be done with previous versions but it is a little tricky.  I usually just used Acrobat since chief made it difficult. Now you can shorten the link or possibly even make it invisible with no text or same color as background text.  This allows you to use an image as the link zone which makes it easier to recognize for most people.  I have not tried it myself in x15 yet though.  The other option is to use QR codes so that even your printed PDFs can provide a link.
You can do as chopsaw says, but many of us use a 3rd party tool like Kuula to setup something like this as it has more functional tools for such a thing.
  • Upvote 2
Amazing thank you everyone for our input on this topic! I will look into Kuula! All the work I have seen looks amazing.
Does Kuula also edit lighting for the views? They seem very crisp. Here are some of the current 360's I am working on, still struggling with getting the lighting correct and perfect.
Starting to think it's my video card that needs updating?
https://accounts.chiefarchitect.com/360/view?share=446140652595013
https://accounts.chiefarchitect.com/360/view?share=501132211214850
https://accounts.chiefarchitect.com/360/view?share=382745353543013
Look into Panorama Sets in Twinmotion instead.
Only because if you ever make changes to your model you only need to re-import your model and all your panorama images will still be there.
No need to create any new images.  Then you just re-export your panorama set to the cloud and your client can use the same link to see the updated walk through.
Plus there are many more options available in the walk through than Kuula. Your client can walk around, change time of day etc…
and it’s free.
  • 2 weeks later...
