Accounting Codes - Where Do They Live and How Can I Update?
I am working on integrating CA x14 into our broader workflow and bookkeeping and want to be able to use the Accounting Codes.  In order to do this I need to be able to do two things:
1 - See all of the Accounting Codes for all of the objects/materials/etc.  (Every possible iteration)
2 - Mass update this information (via query, file replacement, export/import, etc.)
I have been working on this for a few hours and have searched this forum but haven't found what I'm looking for. It is not practical to take the material lists and manually update every row whenever it is generated.
I know they have an integration agreement with Buildertrend, who is probably responsible for these codes.  Since these appeared to be defined on the library-level I started digging into the various CALIB (SQLite3) files but haven't found references to the codes in the tables.  That makes me think this information is actually a level higher up.
Preface that I do not use the material list function.
All objects/symbols have a component panel in its respective dialogue box that reports its accounting code. You would need to open each component and change its accounting code and then set that object to default, such as walls, and then save this to a template or library.
It would probably be easier with framing for instance to have all framing report to a custom schedule whose columns are limited to only one column "Code" and then choose open row object and drop in the macro %accounting_code% in the code designation of the OIP
So that it reports the accounting code to the code column in the master material list
or you can simply past =accounting_code in the code column of your material list or type in your own codes.
1010 - Building permits
1020 - HBA assessments
1030 - Warranty fees
1110 - Blueprints
1120 - Surveys
1210 - Lot clearing
1220 - Fill dirt and material
1300 - Demolition
1400 - Temporary electric
1420 - Individual wells
1430 - Water service
1440 - Septic system
1450 - Sewer system
1460 - Gas service
1470 - Electric service
1480 - Telephone service
1490 - Other utility connections
2000 - Excavation and backfill
2010 - Plumbing - ground
2100 - Footings and foundation
2105 - Rebar and reinforcing steel
2110 - Concrete block
2120 - Rough grading
2130 - Window wells
2200 - Waterproofing
2300 - Termite protection
3100 - Structural steel
3110 - Lumber 1st package
3120 - Lumber 2nd package
3130 - Lumber 3rd package
3140 - Trusses
3150 - Miscellaneous lumber
3210 - Framing labor draw #1
3220 - Framing labor draw #2
3230 - Framing labor draw #3
3300 - Windows
3350 - Skylights
3400 - Exterior siding
3410 - Exterior trim labor
3500 - Flatwork material
3550 - Flatwork labor
3610- HVAC rough
3720 - Plumbing rough
3810 - Electrical rough
3910 - Gutters and downspouts
4100 - Roofing material
4150 - Roofing labor
4200 - Masonry material
4250 - Masonry labor
4300 - Exterior doors
4350 - Garage door
4400 - Insulation
4500 - Fireplaces
4600 - Painting exterior
5100- Drywall
5200 - Interior trim material
5250 - Interior trim labor
5300 - Painting interior
5400 - Cabinets and vanities
5450 - Countertops
5510- Ceramic tile
5520 - Special flooring
55S0 - Vinyl
5540 - Carpet
5610 - Hardware
5620 - Shower doors and mirrors
5630 - Appliances
5700 - HVAC final
5710 - Plumbing final
5720 - Electrical fixtures
5730- Electrical final
5810 - Wall coverings
5890- Special finishes
6100 - Clean-up
6200 - Final grade
6300 - Driveways
6400 - Patios, walks
6450 - Decks
6490 - Fences
6500 - Ornamental iron
6600 - Landscaping
6700 - Pools
Assorted Fixtures
Assorted Floors
Exterior Trim Material
Geometric Shapes
Interior Doors
Uncategorized Items
Can you elaborate on these?  What exactly are you updating in each scenario?
My cost/accounting codes do not necessarily align with those in CA.  I am trying to prevent coding a solution between CA and my other software that would change the built-in codes.
By knowing how many codes there are, and what they are, I can better understand the scope and logic behind everything.  The next step would be to change the master list to my own codes.
You are trying to prevent coding a solution?  Did I read that correctly?
I posted all the codes earlier in the thread.  I just used the drop down list Glenn mentioned and copied the text from a screenshot using one of my other apps.  I don't know of anywhere else they can be copied.  At any rate, yes, you could change the master list so that it will automatically update all the appropriate codes to match yours, but that's a lot of work.  Here's something to think about:
Are you actually going to use the Material List directly from Chief or are you going to make other tweaks?  If you're going to make other tweaks anyway (which most people do), why not simply copy/paste or export/import to a spreadsheet template where all the accounting code changes are just made automatically?
Yes, I already have enough bespoke code and processes to manage and maintain. Spending time now changing that master list will save multiples of that time later.
I am trying to move beyond tweaking a Material List at all once it is generated.  Yes, I absolutely could make changes at this stage, but that step should not be necessary.
Thank you for the list and your responses.  It's very helpful.  I understand I am coming at this from a different direction of a typical user.
Quote
Where/how do I go about doing this?
1 minute ago, glennw said:
You can also find it in the ML.
Ya, I knew they were there too.  What I guess I was really trying to communicate is that I didn’t know if any other way they could be copied aside from those drop downs.
These are all happening too far into the process... ie. after the project starts being designed.
I want to set all the codes BEFORE any given plan is started.  Therefore whatever is designed will have my codes attached off the bat.
Sounds reasonable that an End User would want to do this esp. if they don't work with BuilderTrend, but I think you'll need to make a Feature Request
for Access to those Codes in Chief , for example through Preferences > Materials List > (new tab) Accounting Codes
( it's quite possible BT uses Industry Standard Acct. Codes? that CA assumes we all use )
This isn't currently possible.
  • You can set your own codes in all the Components in your Default Settings but not all object have defaults and not all Components are accessible from the Defaults.
  • You can also set all the desired codes in your Master List which can be done before you start your plan, BUT, even after all the work put into generating that Master List (which I think will be far more than you think), you'll still have to Update From Master (which would have to be done after the fact and in a pretty specific manner if all you want to do is change the accounting codes).
I know its not what you want, but I'm going to very strongly recommend you abandon your current course and just use a spreadsheet template to make the changes.  Copy/paste or export/import is a very small price to pay for avoiding all the problems you're going to run into.
abandon your current course.
Understood, hopefully this changes in the future.  Having worked on that side of things in a previous career, I'm not holding my breath.
  • 8 months later...
1110 - Blueprints
1120 - Surveys
1210 - Lot clearing
1300 - Demolition
1450 - Sewer system
1460 - Gas service
2130 - Window wells
3140 - Trusses
3300 - Windows
3350 - Skylights
3610- HVAC rough
4350 - Garage door
4400 - Insulation
4500 - Fireplaces
5100- Drywall
5450 - Countertops
5510- Ceramic tile
55S0 - Vinyl
5540 - Carpet
5610 - Hardware
5630 - Appliances
5700 - HVAC final
6100 - Clean-up
6200 - Final grade
6300 - Driveways
6450 - Decks
6490 - Fences
6600 - Landscaping
6700 - Pools
Assorted Fixtures
Assorted Floors
Geometric Shapes
Interior Doors
Uncategorized Items
Thank you for this list!!  Where would I go in the software to locate this list and does CA notify users of changes in this list?
    33832
    raynos
    raynos
