cbucks Posted November 26, 2022 Share Posted November 26, 2022 Good day! I am trying to make a large shed like the attached photo but can't seem to figure out how to do. Plan attached Beach House Floor Plan Adjustments .plan Link to comment Share on other sites More sharing options...
cbucks Posted November 26, 2022 Author Share Posted November 26, 2022 Added this additional photo to show the shed dormer front is flush with the 2 floors below, the roof overhangs a bit Link to comment Share on other sites More sharing options...
Alaskan_Son Posted November 26, 2022 Share Posted November 26, 2022 I would not think of that as a dormer at all. Its really just a box with a relatively shallow pitch roof. The dormer effect is being created by a steeper pitch roof facade that just wraps around the building. At least that's what it looks like to me. This is how I would handle it... 1 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted November 26, 2022 Share Posted November 26, 2022 I agree with Mike, this is not a Real Dormer, and Chief's "Auto Dormer" Tools won't deal with this well, so just learn how to do it manually, as it not as hard as it may seem to notch a Roof plane at the Ridge and pull it down opening a Hole to allow the 3rd floor Walls to pop up. Chief has a KB article and Video on doing manual Dormers ........ https://www.chiefarchitect.com/support/article/KB-00449/creating-a-manual-wall-dormer.html https://www.chiefarchitect.com/videos/watch/1521/manually-drawing-dormers.html?playlist=95 and I think Eric ( @solver ) may have some too IIRC. Mick. Link to comment Share on other sites More sharing options...
cbucks Posted November 26, 2022 Author Share Posted November 26, 2022 2 hours ago, Alaskan_Son said: Thanks very helpful that is exactly what I am trying to accomplish, do you mind sharing the plan file of the attached I can see how you did that. Link to comment Share on other sites More sharing options...
GeneDavis Posted November 27, 2022 Share Posted November 27, 2022 I think its lovely. Doing an as-built for an addition? Link to comment Share on other sites More sharing options...
cbucks Posted November 30, 2022 Author Share Posted November 30, 2022 Thanks I am having a bear of a time trying to make this design does anyone have an example I can try to decipher / emulate Link to comment Share on other sites More sharing options...
Kbird1 Posted November 30, 2022 Share Posted November 30, 2022 1 hour ago, cbucks said: Thanks I am having a bear of a time trying to make this design does anyone have an example I can try to decipher / emulate It should work fairly easily doing it like Michael showed above, ie built a 3 story building ( 1/2 height 3rd story?) and let chief put the Roof on Auto, turn off auto roof and then on the 2nd floor draw a roof plane over the Hip walls ( can draw 1 and copy reflect it to other side ) and then join them together. Then cut the notches, using 2 breaks to get the "U-shape" plane. I usually pull this cutout wider than the house and then let chief "snap" the cut back to the walls. I'll take a quick look at your plan above..... Mick. Link to comment Share on other sites More sharing options...
Kbird1 Posted November 30, 2022 Share Posted November 30, 2022 18 minutes ago, Kbird1 said: I'll take a quick look at your plan above..... I stripped your plan down to a single floor due to other issues and auto built the 2 upper floors with a gable roof auto ( 4/12) and then did as above instructions, going 12/12 on the 2nd floor so ridge meet nicely. I don't know the real ceiling heights for the build so you will likely need to play with this some. M. PLAN FILE : BeachHouse_MHD.plan Link to comment Share on other sites More sharing options...
Alaskan_Son Posted November 30, 2022 Share Posted November 30, 2022 4 hours ago, Kbird1 said: It should work fairly easily doing it like Michael showed above, ie built a 3 story building ( 1/2 height 3rd story?) and let chief put the Roof on Auto, turn off auto roof and then on the 2nd floor draw a roof plane over the Hip walls ( can draw 1 and copy reflect it to other side ) Very close to what I did but one small difference: I simply selected one the of automatically generated roof planes, clicked the Copy/Paste tool, clicked the Paste Hold Position tool, opened the copy up, Locked the Ridge Top Height, changed the pitch, and then placed a couple breaks, reshaped, copied, and reflected. 1 Link to comment Share on other sites More sharing options...
Doug_N Posted November 30, 2022 Share Posted November 30, 2022 I did a brief video that illustrates one possible method for making the "shed dormer". https://1drv.ms/v/s!Am8Ktm_KVQE5hP1wpWOfazmGUWO3Wg?e=SoF6sx Link to comment Share on other sites More sharing options...
cbucks Posted January 6, 2023 Author Share Posted January 6, 2023 Thank you everyone for your help! You are what make the Chief community great! Thanks! Link to comment Share on other sites More sharing options...
