Gawdzira Posted January 28, 2015 Share Posted January 28, 2015 The contractor for this project (rightly so) said that he was confused by the elevations due to the building having skewed wings on each side. Not any more since I was able to fade out the skewed portion of the elevations with our new semi transparent fills. The fill on these uses a white fill with 40% transparency. El Fade.pdf Link to comment Share on other sites More sharing options...
kMoquin Posted January 28, 2015 Share Posted January 28, 2015 Nice Alan ! El of an idea. Link to comment Share on other sites More sharing options...
joey_martin Posted January 28, 2015 Share Posted January 28, 2015 We have been able to do this in the past by using the EDIT LAYOUT tool and select what you wanted "faded" and changing the color to gray. I use this method when doing sections and I want the building behind to "fade". Link to comment Share on other sites More sharing options...
HumbleChief Posted January 28, 2015 Share Posted January 28, 2015 Joey, Didn't that require selecting each item and changing the color in Layout View? And wouldn't those changes be lost if you updated the Layout View? Truly curious as to your work flow, and it seems the new tool adds quite a bit of ease to the process. Am I mistaken? Link to comment Share on other sites More sharing options...
Kiwideziner Posted January 28, 2015 Share Posted January 28, 2015 The new tool saves a heap of time and is still live, also good to show below grade foundations. Link to comment Share on other sites More sharing options...
HumbleChief Posted January 28, 2015 Share Posted January 28, 2015 The new tool saves a heap of time and is still live, also good to show below grade foundations. That's what I'm thinking too. What might we be missing Joey? Link to comment Share on other sites More sharing options...
joey_martin Posted January 29, 2015 Share Posted January 29, 2015 It would save time...but using SHIFT SELECT makes it pretty quick to turn those gray, and I only do it when I'm ready to create the PDF, not every version. Link to comment Share on other sites More sharing options...
HumbleChief Posted January 29, 2015 Share Posted January 29, 2015 It would save time... That's the whole idea right? Link to comment Share on other sites More sharing options...
