GeneDavis Posted June 18, 2022 Share Posted June 18, 2022 I manually placed a pair of LVLs which make a beam into which trusses and rafters head. In the spec, I selected ROOF BEAM as role. They report into the subfloor section. Why? Link to comment Share on other sites More sharing options...
rgardner Posted June 18, 2022 Share Posted June 18, 2022 4 hours ago, GeneDavis said: I manually placed a pair of LVLs which make a beam into which trusses and rafters head. In the spec, I selected ROOF BEAM as role. They report into the subfloor section. Why? How did you place it? Was it a copy from floor framing? Link to comment Share on other sites More sharing options...
Kbird1 Posted June 18, 2022 Share Posted June 18, 2022 Technically , in Chief anyway, a horizontal beam is not considered a Roof Beam but a Floor/Ceiling Beaming, Roof Beams are pitched per the roof pitch : x:12 , and it may depend on what floor you placed it on whether "chief decided" it was a Floor or Ceiling Beaming. Link to comment Share on other sites More sharing options...
robdyck Posted June 18, 2022 Share Posted June 18, 2022 Select one of those lvl's, open the dbx ,then click and inspect the components tab. I repeated that operation using a general framing member. Components / ID. Link to comment Share on other sites More sharing options...
GeneDavis Posted June 18, 2022 Author Share Posted June 18, 2022 It was a combination of things. The main floor framing directly below has the pair of LVLs as a drop beam. I copied them then went to floor 1 where I have the roof, pasted and held position, then edited height, member height, and role (roof beam). Not enough to get into material list as wanted, so I deleted and manually placed and all OK now. Link to comment Share on other sites More sharing options...
rgardner Posted June 18, 2022 Share Posted June 18, 2022 4 hours ago, GeneDavis said: It was a combination of things. The main floor framing directly below has the pair of LVLs as a drop beam. I copied them then went to floor 1 where I have the roof, pasted and held position, then edited height, member height, and role (roof beam). Not enough to get into material list as wanted, so I deleted and manually placed and all OK now. You can do it that way but you have to change it in the components tab as mentioned above: 4 hours ago, robdyck said: Select one of those lvl's, open the dbx ,then click and inspect the components tab. I repeated that operation using a general framing member. Components / ID. Link to comment Share on other sites More sharing options...
