buzzsaw204 Posted May 18, 2022 Share Posted May 18, 2022 in X14...recently, idk what i did, i lost the ability that turn Off the non-object Layers, when an Object is Selected. before, when i select an object, only the Layers of that object is displayed (turn On) and all other Layers is turn off Automatically. Isolate layer? now idk what i did, now when a select the object, all layers stays On, and not isolate anymore. My X12 Setting still has it, and working as is should..... Link to comment Share on other sites More sharing options...
Chopsaw Posted May 18, 2022 Share Posted May 18, 2022 Make sure "Show All Layers" is not selected when you click the gear. 2 Link to comment Share on other sites More sharing options...
Solution Kbird1 Posted May 18, 2022 Solution Share Posted May 18, 2022 It sounds like you have set the ALDO's Show All Layers Option to on........ 2 1 Link to comment Share on other sites More sharing options...
buzzsaw204 Posted May 18, 2022 Author Share Posted May 18, 2022 6 minutes ago, Kbird1 said: It sounds like you have set the ALDO's Show All Layers Option to on........ YESSSSSSS!! i was clicking & playing on all those Checks the other day. and couldn't back track & remembered what i've clicked, that caused that. thx u KB!! Link to comment Share on other sites More sharing options...
Kbird1 Posted May 18, 2022 Share Posted May 18, 2022 2 minutes ago, buzzsaw204 said: thx u KB!! Thanks for the thanks Buzz , that happens so little around here , so it's appreciated. 2 Link to comment Share on other sites More sharing options...
EsteeChief Posted May 30, 2022 Share Posted May 30, 2022 On 5/18/2022 at 6:40 PM, Chopsaw said: Make sure "Show All Layers" is not selected when you click the gear. Thanks. It's off. didn't solve my problem... Link to comment Share on other sites More sharing options...
rgardner Posted May 30, 2022 Share Posted May 30, 2022 24 minutes ago, EsteeChief said: Thanks. It's off. didn't solve my problem... Well if this didn’t solve your problem then it’s a different issue. Probably best to start your own post and post pictures if you can. Link to comment Share on other sites More sharing options...
EsteeChief Posted May 30, 2022 Share Posted May 30, 2022 14 minutes ago, rgardner said: Well if this didn’t solve your problem then it’s a different issue. Probably best to start your own post and post pictures if you can. On 5/18/2022 at 6:37 PM, solver said: I don't understand what you are asking -- maybe this? no, but Thanks Link to comment Share on other sites More sharing options...
Kbird1 Posted May 30, 2022 Share Posted May 30, 2022 20 minutes ago, EsteeChief said: 4.52 MB You are replying in the Wrong Thread again Estee...ie NOT your Own.... Link to comment Share on other sites More sharing options...
Kbird1 Posted May 30, 2022 Share Posted May 30, 2022 24 minutes ago, rgardner said: Well if this didn’t solve your problem then it’s a different issue. Probably best to start your own post and post pictures if you can. Estee Has , She posted to the wrong thread....... Link to comment Share on other sites More sharing options...
