Default sets
Bob_Johnston
Go to solution Solved by Kbird1,
That's what you will have if that plan was started in HD Pro ? ( in your Sig. )
You can Import the Others though now you have Chief from the Default Residential Template.
File>Import>Saved Plan Views> (browse out to X13 Template Folder ) . select Residential Template . OK > ALL
Thanks KBird
The problem was a legacy issue from starting out on Home Designer. I did what you suggested and any new plans using the provided templates have the correct default sets. Unfortunately the plan I was working on did not update so I'll have to figure out a workaround (or redo it).
Since you have migrated from HD Pro to Chief Architect Premier, your situation is a going to be different then most.
I would not recommend that you migrate your templates, toolbars, hotkeys or any other settings from HD Pro into Premier.  I think you will be much better off if you start with the out-of-box settings from Premier.  If you have already migrated things, you can always get back to the installed settings by just renaming the folder in your user data folder.  When you launch Chief, the program will automatically create new folders and transfer the installed content into them.  This is the quickest and easiest way to get back to factory installed settings.
As for bringing any legacy plans forward, if you want to have all of the same settings that you have when you start a new plan in Chief you either have to import them all or start a new plan and then use the edit area tool to copy your model into the new plan.  Either way is a bit of a pain and require some manual work.
  • Solution
53 minutes ago, Bob_Johnston said:
Thanks KBird
sorry looks like my brain got ahead of my fingers late last night, and I was thinking Saved Plan Views (SPVs) apparently not Default Sets.
However they can be imported just like the SPVs from the Default Residential provided by Chief.
Open the Default Residential Plan Template  ------  File> New From Template  should take you right there....
Then File EXPORT and export the Default Sets, and Layersets  to a backup directory/folder for future use.
Now in YOUR Plan     goto File > IMPORT and import the Default Sets and then Layer Sets you just exported.
You can also import the SPVs directly into You Plan as Mentioned and also the Plan Defaults if needed which should more or less give you a full X13 based Plan.
Mick.
