Garage floor shows under door on exterior.
Larry_Sweeney
Levis & Chopsaw...................Thanks for getting back to me so quickly. Yes, those were the threads I was looking for. The one problem I find with this solution, unless I'm doing something wrong, is that you get the "almost" correct look for garage doors, but for a walk-in door the exterior casing extends to the bottom of the concrete floor finish. On the garage door I get a thin layer of the jamb across the boot of the garage door on top of the cement. I guess we just "live with it" and hope that someday CA will fix this. Have a great day.
If you have to show the Garage Floor sloped to the door for Code like I do, I leave the floor out of the room,
and then use a Polyline Solid drawn in Elevation, which I then break through the Doors over the foundation wall.
*Not automatic but same method for a Flat floor works fine too.
image.thumb.png.e692d8ae31d19a23abd1c6675bcdce45.png  image.thumb.png.212aa2bd5d7a3a195277ae71ff5b419a.png image.thumb.png.7e84f328496006379a495689f5310e26.png
