carowe Posted March 31, 2022 Share Posted March 31, 2022 Is there a way to partially frost a shower door in CA? I am trying to recreate the attached shower door/glass and tried to look this up using every keyword I could think of. Appreciate any ideas/suggestions! Link to comment Share on other sites More sharing options...
ericepv Posted March 31, 2022 Share Posted March 31, 2022 I think applying a material region may be your best bet. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 31, 2022 Share Posted March 31, 2022 I would try a wall material region using a frosted glass from the lib. Link to comment Share on other sites More sharing options...
Gawdzira Posted March 31, 2022 Share Posted March 31, 2022 Depending on your rendering style, maybe adding a frosted glass polyline solid to the interior of the glass panel could work. I know there are issue with raytracing and viewing through 2 pieces of glass so this might not work but it would be an easier solution than making a custom texture. Link to comment Share on other sites More sharing options...
MarkMc Posted March 31, 2022 Share Posted March 31, 2022 Custom door symbol-material regions for walls. Bit tricky to get the frosted glass to match between the two (I didn't try) part frosted.zip 1 Link to comment Share on other sites More sharing options...
Gawdzira Posted March 31, 2022 Share Posted March 31, 2022 Super thin poly solid placed in front of the door panel. RTRT Link to comment Share on other sites More sharing options...
