DesignTech Posted March 6, 2022 Share Posted March 6, 2022 Has anybody had any success creating a roof cricket to fill in a section such as this on a prow front roof? Not an ideal design, but this what the Owner wanted. File is a little large to attach Brian Chief Architect Premier x13 Link to comment Share on other sites More sharing options...
VHampton Posted March 6, 2022 Share Posted March 6, 2022 Rain water run-off from the main gable is going to cascade against the outside wall - (where the lowest portion of the roof slope terminates) That's where he wants a cricket - inside the wedge. You could copy the main roof. Rotate it. Drag the ridge down to make just a small triangular section. Manually connect the dots and place the cricket in such a manner until it's snug against both outside wall(s) and where the new valley occurs. 1 Link to comment Share on other sites More sharing options...
CharlesVolz Posted March 7, 2022 Share Posted March 7, 2022 Place a serious roof plane sloped away from the wall to the left and then add the cricket. And a gutter. Best, Charles Link to comment Share on other sites More sharing options...
builtright3 Posted March 7, 2022 Share Posted March 7, 2022 16 hours ago, DesignTech said: Has anybody had any success creating a roof cricket to fill in a section such as this on a prow front roof? Not an ideal design, but this what the Owner wanted. 16 hours ago, DesignTech said: It’s hard to tell from this angle but can you extend the roof down to the window and still do a cricket under it. You would want to hold it back at least a foot or two but you would still maintain your prow design and you would still do the lower cricket, but it would help a lot with the water runoff and you can also do a gutter. Brian Chief Architect Premier x13 Link to comment Share on other sites More sharing options...
builtright3 Posted March 7, 2022 Share Posted March 7, 2022 The main thing to do is to stop as much splash and water pooling as you can. Link to comment Share on other sites More sharing options...
SNestor Posted March 7, 2022 Share Posted March 7, 2022 It's really fairly simple to create a "cricket" once you know how to do it...watch the video; Quick Tip: How to create a "cricket" roof plane - Watch Video 1 Link to comment Share on other sites More sharing options...
robdyck Posted March 7, 2022 Share Posted March 7, 2022 4 hours ago, SNestor said: It's really fairly simple to create a "cricket" once you know how to do it...watch the video; Quick Tip: How to create a "cricket" roof plane - Watch Video Nice Video Steve. One thing that could be simplified is you could eliminate that 90 degree rotation of the roof plane. If you just start the roof plan where you want it, like you mentioned in your video, Chief will pick up the existing roof elevation. Makes crickets / saddles really easy. Link to comment Share on other sites More sharing options...
