Rafter spacing 16" o/c NOT 24"
buzzsaw204
The default roof rafter spacing can be specified in either the Build Roof dialog or the Build Framing dialog.  The actual roof rafter spacing that is being used will be shown in the Roof Plane Specification dialog.
If you change it in the Build Roof or Build Framing dialog, and your plan already has existing roof planes, they won't necessarily update.  This will depend on whether or not you have Auto Rebuild Roofs turned on.  If you want to change all of your existing roof planes, you could also use the Edit All Roof Planes tool.
Once you have modified the rafter spacing, your roof framing still won't update automatically unless you have Automatically Build Roof Framing turned on.  If it's turned off, you will need to manually rebuild your roof framing to see the changes.
Normally, if you change the rafter spacing in the Build Framing dialog, you should see this message:
