Jambruins Posted February 28, 2022 Share Posted February 28, 2022 Attached are two pictures. One shows the 30' dimension of the garage and the other picture shows the dimensions to the garage door openings. I use the auto exterior dimensions to get my overall dimensions and then I use a point to point dimension to get my openings. However, the opening dimensions keeps getting reset back to the overall 30' dimension? Why is this happening? It is not only this plan, it happens in my other plans as well. Link to comment Share on other sites More sharing options...
Jambruins Posted February 28, 2022 Author Share Posted February 28, 2022 I know I can change the auto exterior dimensions to do this but I like to dimension to the center of windows/doors in the floor plan so that would mess that up. Link to comment Share on other sites More sharing options...
SHCanada2 Posted February 28, 2022 Share Posted February 28, 2022 5 hours ago, Jambruins said: Why is this happening? are you pressing the auto exterior dimension after you put in the p2p dimension, or are you suggesting you go to another view and come back and now they are gone? I use a separate dimension layer for dimensioning foundations. i auto do them first and then manipulate the auto line to be where I want or p2p it. I have never seen the p2p vanish 1 Link to comment Share on other sites More sharing options...
glennw Posted March 1, 2022 Share Posted March 1, 2022 7 hours ago, Jambruins said: I know I can change the auto exterior dimensions to do this but I like to dimension to the center of windows/doors in the floor plan so that would mess that up. Auto Exterior Dimensions will dimension to opening centres. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 2, 2022 Share Posted March 2, 2022 On 2/28/2022 at 3:07 PM, jasonn1234 said: I have never seen the p2p vanish Perhaps if the Foundation (Auto?) Rebuilt for some reason and the sizes changed ? M. Link to comment Share on other sites More sharing options...
robdyck Posted March 2, 2022 Share Posted March 2, 2022 On 2/28/2022 at 10:26 AM, Jambruins said: Why is this happening? You are using the dimension tools incorrectly. You're creating points only at the 2 corners and the rest of the dimensions are grabbing the openings. You need to create proper dimension default settings for your foundation plans that will locate the center or the sides of the openings. If you rebuild the foundation the manually placed dimensions locating the door openings will lose that locate. So, If using manual dimensions, don't use auto-rebuild for foundations, or the build foundation tool. Auto - foundation pairs nicely with auto-dimensions. If and Once dimensioning needs to be cleaned up manually, then make foundation adjustments manually as well. Link to comment Share on other sites More sharing options...
dougbbuilders Posted March 24, 2023 Share Posted March 24, 2023 On 2/28/2022 at 4:07 PM, SHCanada2 said: are you pressing the auto exterior dimension after you put in the p2p dimension, or are you suggesting you go to another view and come back and now they are gone? I use a separate dimension layer for dimensioning foundations. i auto do them first and then manipulate the auto line to be where I want or p2p it. I have never seen the p2p vanish I can't seem to find anywhere, but how do you create a separate dimension layer for your foundation? I know it must be simple, but I am not sure what to do Link to comment Share on other sites More sharing options...
SHCanada2 Posted March 25, 2023 Share Posted March 25, 2023 create a SPV for the foundation, set the floor level to 0 in the SPV in the selected defaults set: In my "Currently Using" 3/16 Foundation plan set", it has (if I click the edit). you can create one note the layer set is "Foundation Set Print" edit the dimensions: I have below. you will have to click the + button to add the named dimension set. then once you do, set it to a specific layer: and ensure that layer is on for the layer set you define in the first screen above. mine is called "Foundation Set Print" and it looks like Basically I spent half a day creating these for each scale. It is probably overkill, but I like the dimensions, CAD, callouts, and text separated by layer depending on which SPV I am on Link to comment Share on other sites More sharing options...
dougbbuilders Posted March 28, 2023 Share Posted March 28, 2023 Perfect thank you! Link to comment Share on other sites More sharing options...
