AbeLopez Posted February 27, 2022 Share Posted February 27, 2022 Why is my deck not able to build? Thanks X13 Link to comment Share on other sites More sharing options...
Chopsaw Posted February 27, 2022 Share Posted February 27, 2022 Check your railing wall connections and properties for room definition. If that is not it you may need to post the plan file. Hard to diagnose from the screenshot. Potentially you may need to connect the outer railing wall to the exterior wall of the "tower" with an invisible room divider but no guarantees. Link to comment Share on other sites More sharing options...
Kbird1 Posted February 27, 2022 Share Posted February 27, 2022 My guess would be if you have Room Definition you have turned off the Automatically generated Framing + decking material ( planks) at some point. Link to comment Share on other sites More sharing options...
VHampton Posted February 27, 2022 Share Posted February 27, 2022 As a general observation sometimes it's better to leave "decks" on the ground level. Yes, that feature is readily defined as a roof 'deck' in the real world, but the program can have a mind of it's own. Designate that deck/terrace as a "Balcony". Link to comment Share on other sites More sharing options...
Gawdzira Posted February 27, 2022 Share Posted February 27, 2022 I think we will need to see more of deck pics. 1 Link to comment Share on other sites More sharing options...
