DeniseR Posted February 4, 2022 Share Posted February 4, 2022 I'm designing an unfinished basement with just the 2x4 walls framed in - no cover material nor drywall. How can you do that so in the 3D view you can see the unfished 2x4 walls? I'm using CA x13. Link to comment Share on other sites More sharing options...
ericepv Posted February 4, 2022 Share Posted February 4, 2022 Select the wall and in the DBX, - Go to the 'Wall Types" tab. - Click on 'Define' - In the wall layers box, scroll down to 'Interior Layers' and delete the drywall You also need to be sure you build the wall framing (Build/Framing/Build Framing) In the 'Build Framing' DBX, go to the 'Wall' tab and click on 'Build Wall Framing. then click OK Framing should now be visible in 3D. - Eric Link to comment Share on other sites More sharing options...
MarkMc Posted February 4, 2022 Share Posted February 4, 2022 It would be a good idea to select Copy and give it an appropriate name before deleting those layers. Otherwise ALL of the walls of that type will now not have drywall. 1 Link to comment Share on other sites More sharing options...
robdyck Posted February 4, 2022 Share Posted February 4, 2022 21 minutes ago, DeniseR said: I'm designing an unfinished basement with just the 2x4 walls framed in - no cover material nor drywall. How can you do that so in the 3D view you can see the unfished 2x4 walls? I'm using CA x13. The technique would vary slightly depending on the type of view. Are you wanting to show them in a cross section view for con docs or in a 3d view, just to visualize? Link to comment Share on other sites More sharing options...
DeniseR Posted February 4, 2022 Author Share Posted February 4, 2022 In 3D view just to visualize Link to comment Share on other sites More sharing options...
DeniseR Posted February 4, 2022 Author Share Posted February 4, 2022 Yes, framing is built and I can see the 2x4 walls in the perspective framing overview. I wanted to have the 2x4 walls show in the Full Camera View. I'll try what ericepv suggested. Link to comment Share on other sites More sharing options...
DeniseR Posted February 4, 2022 Author Share Posted February 4, 2022 ericepv - that worked perfectly. Thank you! Link to comment Share on other sites More sharing options...
ericepv Posted February 5, 2022 Share Posted February 5, 2022 You're welcome, glad that worked for you. Link to comment Share on other sites More sharing options...
Kbird1 Posted February 5, 2022 Share Posted February 5, 2022 21 hours ago, ericepv said: Select the wall and in the DBX, - Go to the 'Wall Types" tab. - Click on 'Define' - In the wall layers box, scroll down to 'Interior Layers' and delete the drywall and Choose Frame 3 1/2 or 5 1/2 instead , and as suggested build Framing and turn on Wall framing in 3D views. Link to comment Share on other sites More sharing options...
