jtcapa1 Posted January 6, 2022 Share Posted January 6, 2022 I thought I'd try and use the more of the features of CA in creating my site plans. One I like is the ability to show the length and angle of the lot lines just like the surveyor does in degree's minutes and seconds, along with the length. Sounds simple and I'm sure it is, but for some reason I'm hitting a wall in getting them to display as expected. It has to do with making a setting for the right size of text and then getting it to display the surveyors notation correctly. For some reason I cannot find that setting. This is as close as I've gotten, if I keep forcing it, I'm going to screw up all the other settings. Link to comment Share on other sites More sharing options...
Chopsaw Posted January 6, 2022 Share Posted January 6, 2022 That does not look much like what you would typically see on a survey. I think this is pretty standard in most of North America. 1 Link to comment Share on other sites More sharing options...
robdyck Posted January 6, 2022 Share Posted January 6, 2022 The text size for a displayed line length is controlled by the Text Style for the actual polyline. For a property line in a site plan I use a text size that will be about .125" when printed. For most of my site plans that ends up at about 20"-30" depending on the scale of course. TIP: a much simpler way to control text style (than Chief's OOB settings) is to name your text styles based on the font / text size / bold / underline / uppercase, etc. For the bearing angles, I use the azimuth bearing (just because the angle display is typical in my region) which requires an accurately placed north arrow. 1 Link to comment Share on other sites More sharing options...
robdyck Posted January 6, 2022 Share Posted January 6, 2022 12 hours ago, jtcapa1 said: It has to do with making a setting for the right size of text Single click on the property line, then click Object Layer Properties. You can then select or edit the Text Style. Link to comment Share on other sites More sharing options...
jtcapa1 Posted January 6, 2022 Author Share Posted January 6, 2022 5 hours ago, robdyck said: Single click on the property line, then click Object Layer Properties. You can then select or edit the Text Style. That was helpful. That little box for OLP I kept missing. But I still could not get the azimuth settings and decimal settings to display, even though when I clicked the "define" button, then edited the 'Saved Text Style' to be the size, type and height, I could not get azimuth even though 4 popups into this change, I got to 'Number Style' and the final 'Dialog Number/Angle Style' popped up and I changed to 'Decimal Feet' for number style and 'Quadrant Bearing' for Angle style. That last one would not take on the selected polyline for the lot. I'll call SSA and see what they can help me with. I was going about this wrong. I needed to go into the 'Default Settings', 'CAD', 'General CAD' and then tweak the CAD default settings for that particular layer. That was it. Link to comment Share on other sites More sharing options...
robdyck Posted January 6, 2022 Share Posted January 6, 2022 Just now, jtcapa1 said: But I still could not get the azimuth settings and decimal settings to display You may be referring to 1 of 2 things: • Default Settings / CAD / General Cad or •Polyline Specification / Line Style / Show Length & Show Angle Link to comment Share on other sites More sharing options...
Renerabbitt Posted January 6, 2022 Share Posted January 6, 2022 58 minutes ago, jtcapa1 said: But I still could not get the azimuth settings look @Chopsaw's posted picture. 1 Link to comment Share on other sites More sharing options...
DG1949 Posted May 15, 2022 Share Posted May 15, 2022 On 1/5/2022 at 8:24 PM, Chopsaw said: I think this is pretty standard in most of North America. Thank you, Chop! I just needed a refresher, and voila! Link to comment Share on other sites More sharing options...
22trobbins Posted June 16, 2023 Share Posted June 16, 2023 So I have a question also regarding the labeling of lot lines. is there a way to pull the label off the line, rotate it horizontally and have a leader point to the lot line? in placing my lot plan in layout i've needed to resize the text for viewability, however some of the labels are now overlapping, and I want to clean it up. Link to comment Share on other sites More sharing options...
robdyck Posted June 17, 2023 Share Posted June 17, 2023 21 hours ago, 22trobbins said: is there a way to pull the label off the line The method discussed above does not use a 'label, but rather has Show Length and Show Angle displayed for a line or polyline. These cannot be moved. To have the length and angle displayed in various formats as a label would be relatively complicated and would mean that a site perimeter would need to be drawn with individual lines and possibly utilize some macros for the label. Link to comment Share on other sites More sharing options...
