winterdd Posted January 1, 2022 Share Posted January 1, 2022 Is there a way to slice curved polyline solids as shown with the red line? I am experimenting with these steps I built manually...... Link to comment Share on other sites More sharing options...
Chopsaw Posted January 2, 2022 Share Posted January 2, 2022 Looks like that would have been drawn in plan view so you need to convert it to a solid and use boolean operations. 1 Link to comment Share on other sites More sharing options...
winterdd Posted January 2, 2022 Author Share Posted January 2, 2022 1 minute ago, Chopsaw said: Looks like that would have been drawn in plan view so you need to convert it to a solid and use boolean operations. you are correct chop, let me give your suggestion a try. Link to comment Share on other sites More sharing options...
rgardner Posted January 2, 2022 Share Posted January 2, 2022 Draw it with a railing wall instead set to follow stairs. 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 2, 2022 Share Posted January 2, 2022 15 hours ago, rgardner said: Draw it with a railing wall instead set to follow stairs. If the stairs were built "manually" (psolids perhaps) the railing wall wouldn't work. Link to comment Share on other sites More sharing options...
winterdd Posted January 2, 2022 Author Share Posted January 2, 2022 curved wall (something I never use) actually works too guys. Link to comment Share on other sites More sharing options...
glennw Posted January 2, 2022 Share Posted January 2, 2022 Use a standard curved wall, drag the top down and then drag a top corner down. You can also shape the wall top with break points if required. Link to comment Share on other sites More sharing options...
