goodburger18 Posted November 20, 2021 Share Posted November 20, 2021 Is there anyway i can add End plates and T-plates connectors to I-beams showing the Post & Beam Connection? Link to comment Share on other sites More sharing options...
joey_martin Posted November 20, 2021 Share Posted November 20, 2021 A molding polyline will be the most likely method for some of the connectors. Slabs and polysolids as well. Link to comment Share on other sites More sharing options...
Chopsaw Posted November 20, 2021 Share Posted November 20, 2021 Sure, just draw what you need. You might as well draw your I beams as well so you get a proper section view. You might be able to find some bolts at the 3D Warehouse as threads are a little difficult to draw in chief. Link to comment Share on other sites More sharing options...
scottharris Posted November 21, 2021 Share Posted November 21, 2021 On 11/20/2021 at 11:11 PM, Chopsaw said: Sure, just draw what you need. Expand Here's an example of a detail with ibeam / post connections. You can find a few in the Lake Point sample plan. 1 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted November 21, 2021 Share Posted November 21, 2021 On 11/20/2021 at 10:16 PM, goodburger18 said: Is there anyway i can add End plates and T-plates connectors to I-beams showing the Post & Beam Connection? Expand There is a bonus Beam Catalog with an I-Beam in it , and it not hard with Polyline Solids to make Plates ( save to your Library ) https://www.chiefarchitect.com/3d-library/index.php?r=site/detail/789 there is also some stuff I use in the Simpson StrongTie Library including bolts etc but not sure what the X9 Library has anymore..... https://www.chiefarchitect.com/3d-library/index.php?r=site/detail/796 M. Link to comment Share on other sites More sharing options...
