Door opening with an angled wall on one side
StephenM
8 hours ago, glennw said:
Is this what you are after?
I think it is the right side of the doorway  over the sidewalk that is presenting the issue.
I suppose if you were to square the wall on the main structure it would work....  Is that what you were getting at ?
1 hour ago, Chopsaw said:
I think you will actually need to do what I originally suggested and not use a doorway and use a 2nd level to define the top of the doorway and a room divider to create the opening.
Okay thanks, so anything above the door opening would be a new floor? Not sure if you can help with how I would then go about making this wall (photo attached), if everything above the door opening is considered a 2nd level. I've also attached a photo of how the actual roof sits in relation to the wall.
