How do I make White Board and Batten more visible in 3D perspective.
KurtVds
Go to solution Solved by joey_martin,
4 most effective methods in no particular order:
Material Regions
Polyline solids
An exterior framing layer in your wall definition
Molding lines
...or some combination thereof.
They each have their ups and downs.  Material regions for example require very little exactness since they automatically cut for windows and doors and won't display beyond the wall polyline, but as with most automated features, their behaviors in this regard can also cause some goofy problems from time to time, particularly at outside corners, at abnormal wall intersections/overlaps, or where you actually want the battens to extend beyond the wall polyline.  Polyline solids on the other hand offer a lot more freedom but are obviously going to be a bit more time consuming.  3D Molding Lines are similar to polyline solids in that they are a bit more time consuming but they also have some added benefits like the ability to add a profile and the ability to create more complex path's a bit easier.  Adding a framing layer to your walls is one of the most automatic methods but also typically requires quite a bit of editing to get it looking right.  Pick your poison depending on the specifics of your project, preferred workflow, and on which tools you're most proficient with.
Still works just fine ....... been doing it that way since X9 but haven't tried in X13 , but materials regions didn't used to like Exterior Corners.
https://chieftalk.chiefarchitect.com/topic/16852-board-and-batten-library/?tab=comments#comment-141647
  • 1 month later...
